Results 1 to 10 of 31
    Sprocket bolts coming loose ...
    All six of my rear sprocket bolts are all loosing up. I cant put a nut on the back of them as no room between the carrier. They initially got a lot of CV grease in them and did the best I could to clean it up (q-tips, engine degreaser) and switched to a real bolt with lock washer on other side and holding a little better. Using red lockite too (tried both liquid and gel) but suspect with any trace amount of CV grease its not doing much. I have now put a double lock washer on one and hoping it holds even better(?) but wonder if anyone else has any ideas.
    RZR with Honda RC51 SP2 transplant
    RZR with Hayabusa transplant
    Re: Sprocket bolts coming loose ...
    Jan 2007
    Metamora, Michigan
    Torque to spec. sequence & Safety wire the fasteners
    Also get rid of the lock washers if doing this.
    What are the sprocket bolts threaded into?
    Bolt goes through sprocket into about a 1/2in thick circular flange on the carrier. When you rotate the carrier to tighten the chain it moves the flange in like a diagonal direction so these bolts ends would hit the main carrier housing on back side when rotating so thus cant put a nut on the other side.
    The safty wire is a good idea but would have to track down bolts with holes in them or figure out how to do this ... maybe some sort of snap ring like bracket to fit over the bolt heads to hold them but thats a stretch. Wish the threads were reverse thread but still not sure if they would loosen due to vibration, etc. Tha tis part of the mystery ... dont really know why they are loosening so easy. Seems aligned very well. I might have some slight chain rubbing as very tight clearances but dont know if this explains it either.
    Wish I had a pic to show but cant do this for a few days ...
    If your not have to loosen except for sprocket replacement, clean, clean loctite, then a little spot weld to hold ea bolt in place.
    Blog Entries
    1
    Nordlocks and allen bolts torqued to spec.
    Those seem interesting ... looks like I need to call Fastenal or does anyone else carry them?
    Blog Entries
    1
    I believe McMaster Carr has them also.
    Make sure that they are 180KSI allen bolts like Unbrako or Halochrome........
    Sep 2006
    Groves, Texas
    You can Goggle how to drill for safety wire and the proper way to put wire on.
    Blog Entries
    1
    Safety wire will just keep them from falling out after they come loose.
  1. sprocket spinning?
    By banditbuggy145 in forum Driveline
    Last Post: 07-16-2010, 11:09 AM
  2. The Chain
    By Gotted in forum Driveline
    Last Post: 05-08-2009, 10:40 PM
  3. pilot engine bolts loose
    By LEE1969GB in forum Honda's Pilot & Odyssey
    Last Post: 07-28-2008, 03:49 PM
  4. RPM sprocket mounting
    By SeufererMotorsports in forum Driveline
    Last Post: 10-24-2007, 09:14 PM
  5. Sprocket sizes...
    Last Post: 09-22-2006, 07:41 PM
