Results 11 to 20 of 31
    Re: Sprocket bolts coming loose ...
    Petoskey, Michigan
    Brake cleaner will degrease them better than most things if you wish to really clean them and try red locktite again if nothing else works
    I'd go with the Nordlocks also,but like BD said you have to torque them,its how they work.
    If you try cleaning and locktite again,use the primer.
    Sep 2006
    Groves, Texas
    Safety wire done right will keep them from turning and if they come loose without turning then you have another problem altogether!
    Member flangehead's Avatar
    Apr 2011
    east georgia
    If everything is cleaned up really well,red loctite should hold, with the proper torque applied to the bolt.Hell, I've seen Loctite hold where lock washers wouldn't! Yea, just like nutz4sand said
    The Nord-Locks worked! Didnt clean anything, no Locktite, no safety wires, doesnt matter if there is lube in the hole (did I just say that). These things are my new best friend Check out YouTube demo video of these ...very interesting stuff ...
    RZR with Honda RC51 SP2 transplant
    RZR with Hayabusa transplant
    Good news! BDKW1 knows what he's talking about.
    Can't take complete credit for that one, a buddy of mine from NZ has an old Jimco 10 car that he stuffed a 3.5L Nissan twin turbo V6 in. He runs 934's with 35" tires. It puts out 670ish HP to the ground (if it ever finds traction bad things will happen). Nordlocks were the only way he could keep the CV's from coming loose.
    Well, the Nord-Locks worked for a while. I had three of six come out and the other three were loose! Will just check them daily now.
    Senior Member Gotted's Avatar
    Apr 2008
    Clarkston WA.
    Can you retap the threads replace the bolts with aircraft bolts that are made for vibrations.
    (Grip Airframe Bolt, Drilled Shank)
    https://www.pegasusautoracing.com/pr...sp?Product=AN4
    Thanks. Was also thinking of tapping a little larger to see if holds better.
  1. sprocket spinning?
    By banditbuggy145 in forum Driveline
    Last Post: 07-16-2010, 12:09 PM
  2. The Chain
    By Gotted in forum Driveline
    Last Post: 05-08-2009, 11:40 PM
  3. pilot engine bolts loose
    By LEE1969GB in forum Honda's Pilot & Odyssey
    Last Post: 07-28-2008, 04:49 PM
  4. RPM sprocket mounting
    By SeufererMotorsports in forum Driveline
    Last Post: 10-24-2007, 10:14 PM
  5. Sprocket sizes...
    Last Post: 09-22-2006, 08:41 PM
