Results 1 to 5 of 5
    4 wheeler hubs hold up? 28 spline hubs?
    Well I got my cv joint kit today the 930 with 2 axles. They are 28 spline does anyone know of a vehicle that is 28 spline so I can just buy a hub? I bought raptor hubs but they look way to small and im afraid they will break also with a raptor hub I'm not sure where to put a bearing to hold the wheel in place?
    Re: 4 wheeler hubs hold up? 28 spline hubs?
    ??? Hubs not gonna go onto axles splines. You need a stub axle to bolt to the 930 joint.
    Can I get stub axle any size I want as in thickness?
    Ok, do your already have the center drive section? Trailing arms or a arms? Any plans you are building from, or are you retro fittin something you got. Pics?
    For a hub a 99-02 F-150 front hubs and CVs work with the 28 spline axle. That's what I used.
  1. VW Spline Hubs
    By Rorty in forum Suspension - Wheels & Tires
    Last Post: 02-26-2007, 01:10 PM
