Results 1 to 10 of 12
    Track Width Difference? Front to Rear
    Vendor dirtreaper's Avatar
    Mar 2010
    Toronto, canada
    Hey guys I've noticed on my shredder that the rear width of the tires is not as wide as the front, is this normal practice on buggies? Will it make a difference to widen the rear end to match the front width? IMO it would give me better stability around corners, would I be wrong? I've modified a few things on my build for the better ( I Hope) this would be another?
    Thanks
    Dave
    Re: Track Width Difference? Front to Rear
    Oct 2006
    Pittsburgh, PA
    How much difference is there? I like to keep the front and rear widths (outside of tires) about the same, but I've come across plenty of buggies where the front is slightly wider than the rear. You are correct it is more stable that way. But a narrower rear also makes turning better with a locked rear axle.
    Mar 2010
    Toronto, canada
    I dont know exactly but it's very noticable, also Im not using a locked rear end, more of an lsd atv rear end
    S.W. Michigan
    Years back we started narrower in the front.
    We noticed the improvement when it was changed to run about 1" wider in the front than in the rear.
    so a touch wider in the front is better for steering with a live axle,
    If the front is wider,when the body rolls as in going into a turn ,it transfers more weight to outside front,planting the tire better than the outside rear.Thats at least what I've read.
    Mar 2010
    Toronto, canada
    Thanks guys I kinda like the look of eveness, i'm a straight clean line guy and its bothersom to me to look at it wider in the front
    Senior Member RoosterBooster's Avatar
    Mar 2010
    Cedar City, Utah
    Quote Originally Posted by dirtreaper View Post
    dirtreaper
    i like to use the same tire and the same track front and rear (that is with dirt tires.... obviously the track with sand tires will be different)
    if you drive a lot of high speed on soft surfaces like sandy washes or snow i would highly recommend to go with the EXACT same track.... if your rear is a little smaller it will constantly switch between tracking the left or right front tire groove.... makes the car feel "nervous" and unstable (<<< lol ...i love that smiley)
    Stephan
    "In a totally sane society, madness is the only freedom" J.G. Ballard
    Mar 2010
    Toronto, canada
    Thanks man me too, I live in canada so there are no dunes here, I will mostly ride on trails and mx trax. So I guess even wins.
    Senior Member 54chevy's Avatar
    Nov 2009
    E. Tenn
    Just look at it from this angle
    and not this angle
    It bothered me a little in the beginning but it doesn't anymore. It certainly helps with turning and makes it a little easier to slide through a turn.
    get a set of offset rims bro!
    Last Post: 08-17-2014, 11:00 PM
  2. Replies: 25
    Last Post: 09-16-2010, 08:55 AM
  3. Front Track Width vs. Rear track width ratio. . .for turning radius???
    By atomicjoe23 in forum Suspension - Wheels & Tires
    Last Post: 06-30-2009, 12:48 PM
  4. F/R Track Width
    By Section 8 in forum Suspension - Wheels & Tires
    Last Post: 09-02-2008, 01:23 PM
  5. Difference between the width of a-arm mounts?
    By plkracer in forum Suspension - Wheels & Tires
    Last Post: 08-23-2006, 11:09 AM
