Results 1 to 3 of 3
    Quick Change gears & shafts
    Looking for more info on the Quick Change (QC) gears used in dwarf cars, etc. What is the center-to-center distance of the shafts the gears fit onto in a quick change rearend? How available is shafting with the 6 & 10-spline the gears come with? I've looked all over and can't find an answer to the first question (or what the pitch of the gears is) and haven't really seen a good source for shafting with that spline.
    Re: Quick Change gears & shafts
    6 spline are 3" center to center.
    10 spline are 3.5" C2C.
    The Winters 7" QC use gears that are 2.5" C2C.......
    Sweet, thank you. I did find some shafting in HubCity's catalog so once I see how 3 or 3.5" OC works I can order some gears and see if the shafting will work.
  1. analysing a gear box(f-n-r)
    By gaurav in forum SAE Baja
    Last Post: 09-09-2009, 11:30 AM
  2. Weird sound on RPM box and UJ shafts
    By Montanaminirail in forum Driveline
    Last Post: 06-09-2008, 10:44 PM
  3. site bug...Quick Reply missing...
    By tenaja in forum MiniBuggy.net Lounge!
    Last Post: 10-22-2006, 10:58 AM
  4. Quick change rear end gears for jackshaft
    By MXman in forum Driveline
    Last Post: 10-13-2006, 08:55 AM
