Results 1 to 4 of 4
    newb confused about the rpm gearbox
    May 2009
    athens ontario canada
    Post
    im a moron i know
    but the rpm ger box is that like a tork converter were the more rpms there r the bigger the gear get or is it one ratio were you but the gearbox of the engine in front im a idiot
    Re: newb confused about the rpm gearbox
    Senior Member bugbite's Avatar
    Feb 2009
    northern Idaho
    nope, it's a fixed ratio, but you could use it with a cvt so you have a gas and go rig, one of the main reasons to use the rpm is the reverse as I'm shure you know, the others are is doesn't stick out the bottem so you don't lose any ground clearence, and they weigh less then the honda trannie, one the other side their kinda pricy, anyway hope this helps
    bugbite
    Sep 2006
    New Mexico
    RPM gearbox is available in a bunch of ratio's to fit your car. It gives you a tight flange to flange distance for more travel out of your CV's, ground clearance, reverse, maintains a live axle so traction is not lost and turning is good in dirt. Gives you nuetral on the gearbox. Can provide a input brake for lighter cars or it can be used as and output for additional alternator. When you look at all the benefits it gives you, it's really not that expensive. I think they sell for around $2k.
    May 2009
    that helps alot thaks
    from the canadian
  1. Driven CVT Clutch to Gearbox Mating
    By SCBaja in forum Driveline
    Last Post: 01-31-2014, 03:33 PM
  2. honda civic gearbox at 15000/ 20000 rpm
    Last Post: 02-09-2009, 07:55 AM
  3. 6 Part Forward Reverse Gearbox
    By tooltime in forum Driveline
    Last Post: 07-02-2008, 08:16 PM
  4. RPM Gearbox for Solidworks
    By standfast in forum File Library
    Last Post: 06-19-2008, 08:00 AM
