Results 1 to 5 of 5
    Where to buy these axles?
    Jan 2009
    British Columbia
    Does anybody know where to buy these rear u-joint axles?
    Are they custom made or can you buy them?
    I would like to use this set-up on mine.
    I found this picture on this site. Thanks for your help.
    Re: Where to buy these axles?
    Senior Member Jay1823's Avatar
    May 2007
    Metro Detroit, MI
    Talk to Yoshi, he uses axles like those he may have an idea or be able to sell you a set of his.
    Senior Member Kludge's Avatar
    West of Portland, Oregon
    That looks like the original swing axle setup that short sand cars used ShortSandCars
    Most builders (Including Short) have moved up to IRS (Independent Real Suspension) that use two CV joints (or in some cases U-Joints)
    The Swing axle style will work if you limit the wheel travel so that the axle does not fold under. I believe you can find more discussion by searching the forum.
    /Frank
    What are you building or putting this axle on? How about some pics!
    Senior Member JaRiv's Avatar
    Jan 2009
    SO-CAL
    those are some clean looking axles... WHOS BUGGY IS THAT?
  1. 944 924 axles ????????????? help !!!
    By Xcalibur in forum Projects in Progress
    Last Post: 08-24-2008, 08:52 PM
  2. Finding a candidate for axles
    By anasasisxenophontis in forum Suspension - Wheels & Tires
    Last Post: 08-14-2008, 07:56 AM
  3. axles
    By 455bird in forum Driveline
    Last Post: 06-28-2008, 05:41 AM
