Results 1 to 2 of 2
    KFX450R Powered w/ 4 Link Rear
    Sep 2019
    Northern Cali
    So I had an Idea, what if you made something trophy kart sized, maybe a bit bigger, use a KFX450R quad motor turned sideways, driving a cut down samurai rear axle, and 4 link suspension? Kfx would work good because it has electric start, 5 speed w/ reverse, and has around 40hp stock. Thought about that, maybe with a custom 1.25-1.75" Chromoly "driveshaft", It would be more a trophy truck type, 4 link rear and Dual A arms front. Opinions? Would this even work, and have good power to weight, would it be enough power to be fun?
    Thx
    Re: KFX450R Powered w/ 4 Link Rear
    Axle will be too heavy.There is a much easier way. A long time ago I posted a sketch of an idea i had for a four link with a sprocket and everyone busted my balls. (My 3-link go-kart rear axle concept) I with I was good with solid modeling, could draw it very easily.This guy just stumbled upon the same thing I was saying in about 2007.Skip to about 6 min. Its a lot smaller, but concept is the same.https://youtu.be/hKXr36R7Xp0If I was to do it today, Id look for a used micro sprint rear axle.(or new, if you have the money) Very adjustable, aluminum and unlimited parts availability.F!@#$N photobukit!
  1. 5 Link rear end
    By Joe in forum Suspension - Wheels & Tires
    Last Post: 11-25-2010, 11:49 AM
  2. rear 3 link set up help
    By 1zx14mini in forum Motor - Engine
    Last Post: 09-19-2010, 07:45 AM
  3. 4 link rear end
    By betonblack in forum Suspension - Wheels & Tires
    Last Post: 12-12-2008, 05:31 AM
  4. Three link rear suspension
    By David M in forum Suspension - Wheels & Tires
    Last Post: 12-08-2008, 09:57 PM
  5. 5 Link Rear Set-Up?
    By redbeard in forum Suspension - Wheels & Tires
    Last Post: 02-07-2008, 05:20 PM
