Page 3 of 11 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 107
    Re: Bullnerds Bend-Tech
    #21
    Ok, here ya go. As I said, I do all the design in solidworks. I kick the tube info over to bendtec and all my plate info out to my 5x10 cnc plasma.
    I am attaching some pics of one of my a-arms from start to finish. You see the full assembly, including the jig I designed to build it, then the tube isolated. I click the bendtec icon in my solidworks toolbar, then it ask you to click a sketch. I click on the visible sketch that the tube is structured around, it pops up in the sketch window and I hit ok.
    I then open bendtec and as soon as it pops up you see the entire a-arm with a bunch of circles for segments. I don't have to open it, it's just there when it opens. I click the circles to highlight the tube I want, then I click the tube size and the die size, click submit and it pops up the info I need to bend that tube.
    That is the extent of my use for bendtec, I actually don't know how to do anything else in the program and I don't even save these files. It is so quick to get a print out that I always just go to solidworks first and click on the tube I want if I need it again. I actually have a very detailed, color marked jig book for the components that my employees use to reproduce the parts so I have no need for the files after that.
    www.SinisterSandSports.com
    918-521-3736
    #22
    Very cool! Thanks Yoshi. After I get the hang of BT I'm going to spend more time with SW.
    Those are some beefy arms!
    #23
    There really isn't much to solidworks for doing tubing, it's ubber easy. I could walk you through the basics of creating points for a chassis and then applying structural tubing to them in about 10 min.
    I've been working with solidworks for years and have figured out lots of little tricks as well.
    918-521-3736
    #24
    Bend-Tech Dragon Master
    Nov 2009
    My take - A real CAD program is best for designing the complete car, frame-plates-etc. because its much easier to import references to build around. For me I will always love my basic autocad, its just enough 3D for me. Once I got good with the UCS tools, slicing/sectioning, Polylines and path extrusions its really all I need for my desires.
    Bend-Tech is king for processing the tubing cutting and bending.
    But its hard to do the designing that a good CAD can offer. By designing I mean plotting out suspensions, etc.
    #25
    Jan 2009
    Los Angeles
    You've been busy Bullnerd!
    I have bendtesch also and its been great. Took me a bit of time to figure out but I have the older Version along with the Sheet metal program.
    A great thing about Bendtech is the direct line that you can call and actually speak to a tech to help you out if you have problems with a file.
    I'd like to upgrade to the Updated version but funds don't allow it yet. :-(
    #26
    So I asked if I could play around with the cage design for Ks Bennihanna master piece...just now saw that Benni answered a while back.
    I'll post any crap I come up with here as to not ball up Ks thread.
    Please add comments as to what you'd like to see. I'm guessing.
    Benni, I need the dims pictured. Close is good enough. Then I'll add more dims and you can correct it.
    Rough start...dims are close...except the ones pictured above.
    #27
    Laguna Niguel, Commifornia
    Wanna play around with mine too?
    #28
    Blog Entries
    1
    Quote Originally Posted by flyerrider View Post
    #29
    #30
    Archer is great!
    More subtle..LOL!
    Sure..Add some dims to the pic. I thought you were done with yours.
    Rally style?...for easy access!
  1. Bend tech vs solidworks
    By schwabm in forum The Drawing Room
    Last Post: 05-01-2012, 05:05 PM
  2. If you wanted to get Bend Tech Pro. Get it NOW!
    By nutz4sand in forum MiniBuggy.net Lounge!
    Last Post: 10-28-2009, 02:06 PM
  3. bend tech pro 4.
    By magnum4598 in forum The Drawing Room
    Last Post: 02-15-2009, 10:11 PM
  4. My Bend Tech frame.
    By Andy_1972 in forum The Drawing Room
    Last Post: 01-01-2008, 05:16 AM
  5. bend tech ez software
    Last Post: 10-10-2006, 10:58 AM
