Page 2 of 11 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 107
    Re: Bullnerds Bend-Tech
    I'm not sure what bend selection is? If you mean the die radius then no. Click creat & edit, then Edit, then move bend, then you have to click the bend you want to modify, then a little chart will popup, click change radius. You can enter an amount. I enter a small amount and just click on it until looks cool.
    Your turn, How do you post the pics like you did? I can only do it through MS Paint and it doesnt look as good as yours.
    Thanks. I tried it and it does look much better but how would you accomplish that in the real world? I'm not familiar with how a radius bender works. I'm assuming that's what you would have to have?
    Honestly, I think your pics look better than mine. I used paint too. I just "print sceen" from bendtech, paste into paint, crop and save. Although I bet there's a better way to do it from bend-tech. Just haven't figured it out yet.
    • While looking at your design in bend-tech, do a print screen
    • paste that into paint
    • in paint go to "image/crop"
    • crop the part you want to use
    • go to "edit/copy"
    • go to "file/new" (it will ask if you want to save, i say no)
    • go to "edit/paste "
    • then "file/save as" and your done
    Ahhh...you cropped it, thats the difference, thanks.
    Yeah, theres probably a better way but I havnt found it either.
    Yup, roll bender,I would have to go by eye or to a template. I think bentech has software for that now too.
    Can one of you guys that have the BT and SW post a pic or two?
    Actually someone that imports SW parts into BT, or does everyone just use BT to get the bend info?
    I just confused myself!
    Should be cool once I get the sheetmetal part figured out.
    How'd you get the sprocket in there? I haven't touched the sheet metal stuff yet.
    Thats no sprocket! Its a piece of 10" tubing with a 4-1/2" wall! 1/4" long, LOL!
    I did the sample part in sheetmetal then went right to the tube.
    Thats funny. Good thinkin though.
    I'll post some screen shots tomorrow. I do full modeling in solidworks, click the bendtec plugin within solidworks, then click the structural member I want and it opens up in bendtec. I then click the size tube, the die and it gives me the info for the tube I want. Easy breezy...
    www.SinisterSandSports.com
    918-521-3736
    Thanks Yoshi, thats what I thought.
  1. Bend tech vs solidworks
    By schwabm in forum The Drawing Room
    Last Post: 05-01-2012, 05:05 PM
  2. If you wanted to get Bend Tech Pro. Get it NOW!
    By nutz4sand in forum MiniBuggy.net Lounge!
    Last Post: 10-28-2009, 02:06 PM
  3. bend tech pro 4.
    By magnum4598 in forum The Drawing Room
    Last Post: 02-15-2009, 10:11 PM
  4. My Bend Tech frame.
    By Andy_1972 in forum The Drawing Room
    Last Post: 01-01-2008, 05:16 AM
  5. bend tech ez software
    Last Post: 10-10-2006, 10:58 AM
