Results 1 to 5 of 5
    Scale - please help
    Apr 2008
    South Africa
    Red face
    Hi All.
    I have very limited CAD experience (mostly Autocad). I have some dxf files for laser cutting of some custom components for my buggy suspension. Only problem is that the dxf drawings were drawn on a scale 1:5 and the laser cutters want the drawings 1:1. Is there an easy way to prepare dxf's or dwg's without having to redraw the whole lot?
    Thanks
    Re: Scale - please help
    Vendor yoshi's Avatar
    Sep 2005
    Broken Arrow Oklahoma
    what program are you using?
    www.SinisterSandSports.com
    918-521-3736
    Jan 2007
    Metamora, Michigan
    open the dxf file in autocad. type in "sc" or(SCALE)and hit enter. Select the entire object/enter. Select a base point then type "r" or (Referance)then enter. Then 5/enter/1/enter or the opposite depending on which way you need it scaled. Now type "dxfout"/enter. you can save it over the existing file or rename it as a new file.
    Apr 2008
    South Africa
    Using Autocad - Sorry
    Apr 2008
    South Africa
    RickS - Thanks Mate!! works great!
  1. welding
    By Bugpac in forum Frame
    Last Post: 05-17-2010, 05:03 PM
  2. Another Mini
    By Gene in forum Projects in Progress
    Last Post: 02-21-2010, 08:31 PM
  3. 1/5 scale prototype of buggy!!
    By tomlen in forum Projects in Progress
    Last Post: 12-16-2008, 02:36 PM
  4. 1:3 Scale Ferrari 312PB
    By KWiKSand in forum MiniBuggy.net Lounge!
    Last Post: 12-02-2006, 05:01 PM
  5. A real mini buggy!!!!
    Last Post: 07-27-2006, 04:40 AM
