Results 1 to 10 of 14
    Finned CV problem
    Nov 2007
    Fort Worth Texas
    I have finned CVs on my RPM Gearbox. Back when I got these CVs, I got the Finned CVs because they say they run a lower temperature.
    I was have problems with the CV bolts coming loose, I could not keep bolts tight for more than 5 min of riding. I ended up using Stage-8 bolts to stop the bolts coming loose.
    https://www.minibuggy.net/forum/drive...ome-loose.html
    I was putting new grease in my CVs this weekend. I cleaned the old grease out and was looking the CV over for damage. I noticed the CV fin was bent inward at the CV bolt locations. I think the CV bolt was bending the CV fin inward on the CV and thats why I could not keep the CV bolts tight.
    I going to change to solid body CV.
    I do not think the CV fins are strong enough at the bolt locations
    Re: Finned CV problem
    Wow. Not good. I'd guess you're on the right track - they just can't handle the bolts being tightened up.
    Never seen a cv with that sort of external finning.
    Maybe you could keep those cv's if you make a nice little steel ring with matching bolt pattern to the cv, sort of like a huge washer with holes along the outside for all of the bolts to seat against to keep from bending the housing? They look a little bent too far though...
    Dune 500
    Bend-Tech Dragon Master
    Nov 2009
    Thick billet boot flanges...
    Dec 2007
    PERTH WESTERN AUSTRALIA
    G'Day Stress,I had similar probs with my 930 CV bolts loosening up on the FL800Pilot.I do a lot of racing,enduros etc.The poor ol CV's take a hammering with all the braking,accelerating,high speed stuff..
    I did a lot research on diff washers,then went down to my local supplier to check out the Nordlocks-washers.They come in pairs,and wedge-ramp against eachother.Brilliant design,and YES they work,never had a Lucy since.
    Try em mate,and you'll wonder where they've been all your life.You'll also retrofit your stuff with them as need be.
    Nord-Lock wedge-locking washers | Secure your critical bolted joints with the original lock washer from the bolting experts
    Trying to wear out BEFORE I rust out!..........Now just trying to getouta Bed!
    I drink...........therefore I am!
    I have thought about running those finned jobs on the new car but i am surprised at that deformation ,,,thought they would be better than that. Suppose it is like anything good and bad ones . Are they cheapies ?
    Those washers work good bazz but gotta stop the crush first .
    Talon's YouTube Channel
    Dec 2007
    What torque do they recomend on those? Your torque?Did you overtorque?
    I think they are a great idea.Anything dissapating the heat is def beneficial.
    I'd be tac welding in some metal anti-crush spacers inbetween the fins adjacent to the bolt, for the bolt to torque to.
    Think along the lines of when you see those black spacers in 2 stroke air cooled fins.
    along the lines of bazz, maybe some hardened sleeves all the way through the holes with narrower grade 8 thru-bolts followed by a safety wire session. Hole diameter that close to the edge is making the clamp point on the outside side of the hole less than 1/4" thick
    Blog Entries
    1
    What brand are those CV's?
    I have seen cut down GKN's run successfully on a 10 car.
    Senior Member BorntoBraaap's Avatar
    Jul 2013
    Salt Lake City Ut.
    "Removing" metal to make fins is never a good idea. Less metal can not dissipate the heat that the original mass could. Then to the point that part is weaker is terrible. Now "adding" metal fins, or larger stock with fins cut in would be way better.
    My vote is new ones without fins cut in.
  1. Hayabusa cooling problem in the dunes
    By hermie in forum Cooling
    Last Post: 06-16-2016, 07:05 PM
  2. Arctic Cat 660 Turbo drive clutch seizure problem
    Last Post: 02-02-2014, 02:16 PM
  3. hydraulic clutch problem
    By gvouvakos in forum Controls and electrical
    Last Post: 04-15-2013, 12:56 AM
  4. Another Problem -___-
    By FullThrottleKTM in forum MiniBuggy.net Lounge!
    Last Post: 08-21-2012, 02:38 PM
  5. help cdi problem
    By SLICK WILLY in forum Honda's Pilot & Odyssey
    Last Post: 04-17-2010, 11:39 PM
