Results 1 to 5 of 5
    Hayabusa wiring question
    Jan 2015
    Norco, CA
    will the stock wiring harness support an aftermarket fuel pump, bosch 044?
    While I'm asking wiring questions, I have 2 others, how do I bypass the kickstand switch? I was told this is a simple jumper but I don't want to just cut it out and connect the wires without some consensus
    how do I bypass the tip over switch? currently it is in gooped up with silicone, I'd like to remove it and start cleaning up my wiring.
    Thanks
    Re: Hayabusa wiring question
    The stock pumps draws around 7 amps, while the 044 can pull 12-20, especially when under high pressure. I would run a set of 12 gauge wires straight to the pump to prevent voltage loss.
    I believe the stock wires are 14 gauge.
    The tip over sensor takes a 6800 ohm resistor between 2 wires, but I have been using a 4700 ohm since my original bit the bullet.
    The kick stand sensor is supposed to have a diode. Most people directly jumper the two together, but I chose to use the diode. It will only work in 1 direction. The diode may be for reverse voltage protection, or to prevent another circuit from triggering a false positive, but it isn't explained anywhere.
    There should be a thread somewhere on here regarding those electrical modifications in detail.
    Jan 2015
    Norco, CA
    Thanks for the input, I think I'll be running a separate relay to power up the pump.
    I'll try to dig up a 6800 ohm resister
    do you know which direction the diode faces? I guess I'll be using the search when I get a chance
    The ecu drives a relay for the stock pump too. The 12v hoy to the pump is a yellow wire with a red tracer. Replace the relay and wiring for the new pump. The signal from the ecu can stay.
    I'll look up the diode direction when I get a chance to pull out the wiring diagram again.
    Jan 2015
    Norco, CA
    My current plan is to just use the relay that normally powers the stock pump to energize the new higher amp relay. I know it is just adding more stuff to remove but I need to do something quickly for now.
  1. Hayabusa wiring k8 (gen 2)
    By ad74710 in forum Controls and electrical
    Last Post: 12-06-2013, 06:42 AM
  2. Hayabusa wiring
    By ray2245 in forum Asphalt Runners
    Last Post: 02-08-2012, 05:37 PM
  3. hayabusa wiring
    By Hornet in forum Motor - Engine
    Last Post: 10-21-2007, 07:59 AM
  4. hayabusa wiring?
    By edride in forum Controls and electrical
    Last Post: 09-20-2007, 03:17 PM
  5. hayabusa wiring harness...
    By yoshi in forum Controls and electrical
    Last Post: 07-23-2006, 07:18 PM
