Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
    Re: Electrical loads and consumption for busa buggy
    Quote Originally Posted by midgetll_busa View Post
    4- 12v dc motor Drives the alternator with belt with higher ratio depends on motor rpm will make the pulleys ( this setup i am thinking at now) switching the 12dc motor from extra battery then feed both battries from the alternator, the drawbacks of this system that the amparage of the motor will be around 30 amps and the alternator will be high amps like 100amps, so i can get around 60 amps including the losses ( any body tried this setup before?)
    guys your feedback and inputs will be highly recommended and appreciated
    thanks in advance
    Aside from the fact this violates the second law of thermodynamics, its a great idea.
    You would be energy ahead to just add the second battery and drain it direct into the fans than trying run a motor from a battery to run an alternator to charge the battery.
    Jan 2015
    Norco, CA
    This would be awesome if you can make it work! but unfortunately it falls into the perpetual motion conundrum, you can't get more energy out than you put in.
  1. 2 Seater Busa Buggy
    By JD66 in forum Projects in Progress
    Last Post: 04-04-2016, 03:33 AM
  2. Mini Buggy- how much electrical power do bike motors make?
    By brooksie2113 in forum Controls and electrical
    Last Post: 05-19-2014, 01:39 PM
  3. turbo busa buggy dunning t-day
    By fns in forum Show off your toys in here!
    Last Post: 12-12-2012, 04:38 PM
  4. Busa buggy and chains
    By xtatdsm in forum Driveline
    Last Post: 10-29-2010, 10:56 PM
  5. shifter for a busa buggy
    By hermie in forum Controls and electrical
    Last Post: 01-05-2010, 08:39 PM
