Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
    Re: UPRIGHT DESIGN- HELP NEED MORE STEERING ANGLE
    Give someone here some dimensions, they can probably tell you how wide the rack spreader will need to be.
    ^^Yep cause I see bump steer.
    doesn't look to need too much of a spreader, draw a line thru your inside upper and lower a-arm mount bolts with the rack centered, on that line is essentially where you want the tie rod/spreader connection bolt center at. right now you're inside the line. the issue then becomes at full bump or droop and full lock whether or not the end of the tie rod will hit one of the a-arm tubes.
    Blog Entries
    1
    Quote Originally Posted by Xbird View Post
    Not quite, you need to figure out how far past the king pin angle the steering arm is on the spindle and move you inner out from that plane to match.
    Just from crazy eyeball measure, 3" ea side. But measure it, still not quit sure you got enough on spindle.
    bdkw is absolutely correct on that, my apologies, forgot the "other side" of the equation.
    Its fine, I fixed it 10 minutes after my first post.
    Its done.
    My brain just wasn't on that morning.
    Been balls deep in Thermodynamics.
  1. New Design Hydraulic Power Steering Rack
    By whitedragon64 in forum Controls and electrical
    Last Post: 07-03-2016, 07:56 AM
  2. Steering system design doubt
    By kaushalful in forum Controls and electrical
    Last Post: 07-07-2012, 09:21 AM
  3. Steering system design doubt
    By kaushalful in forum SAE Baja
    Last Post: 07-07-2012, 03:40 AM
  4. Spindle steering arm wrong angle (w/pic)
    By Travitanium in forum Suspension - Wheels & Tires
    Last Post: 11-06-2010, 09:39 AM
  5. Steering angle for turning
    By TEO in forum Suspension - Wheels & Tires
    Last Post: 12-10-2009, 12:47 PM
