Results 1 to 6 of 6
    Ecotec stand alone harness
    Does anyone have a wiring diagram for a stand alone harness for a 2.4 Ecotec? (Spudnut?) I have hptuners to disable vats in the computer but am having a difficult time getting hptuners to connect to the Ecu. I would really prefer to make a harness rather then buy one but not having much luck finding the pin outs I need to do that.
    Re: Ecotec stand alone harness
    Well I found the information I needed and got hptuners to connect the the ECU with a bench harness. Now to trim down the car harness into a stand alone....
    Yuck!
    Good luck dude!
    Yeah, nothing to it.
    It reminds me of the pot of spaghetti I was cooking the other day.
    All kidding aside, I wish you luck on your project.
    Figured I'd throw a update in here incase anyone else is attempting this. I used alldatadiy.com to get the wiring diagrams, I would absolutely recommend it you do have to pay for it but it's not much and the information is complete and accurate. I trimmed down the harness hooked everything up, engine fired up and idles nice. As of now only 2 minor issues first the ECU is for some reason not controlling the fuel pump relay not really a problem as I will be using a different pump and regulator system and the pump will be on its own switch. Second after starting the engine and letting it idle for a bit a slight touch on the throttle pedal brought it to about 3000 rpm and it stuck there I had to shut down the engine. I will look into both and update again. I will clean the harness up when it's time to install it in the buggy and I can finalize the length.
    Very cool, thanks for the update.
  1. Stand alone ECU options
    By fns in forum Motor - Engine
    Last Post: 06-19-2015, 03:18 PM
  2. Hayabysa stand alone harness
    By rupert14 in forum For Sale
    Last Post: 12-05-2012, 10:58 AM
  3. Replies: 9
    Last Post: 08-19-2009, 10:47 PM
  4. R1 stand alone wiring harness
    By ghettosled in forum Controls and electrical
    Last Post: 12-02-2008, 12:25 PM
  5. hayabusa stand
    By 1982shawn in forum MiniBuggy.net Lounge!
    Last Post: 04-12-2008, 07:56 PM
