Results 1 to 9 of 9
    Help with Brake Line setup?
    Jan 2009
    Los Angeles
    How's it going guys! It's been awhile but Im trying to make some time to get back to the buggy setup. I'm in need of better braking!
    The original brake setup just isn't pushing what it should. I've looked into these factory Joyner/Roketa Master cylinders and they all seem to not do so well. So I picked up a few parts to try and get better braking.
    First off, I got a CNC single port 3/4 Master cylinder. I'm hoping that it will be suffice to run 4 way calipers on all 4 corners. First time running a single port Master.
    Maybe some of you guys are more familiar with this Mastercylinder.
    K-fab had recommended a Proportion valve to help getting better braking along with possible parking brake. So I picked up this cheapy from Amazon.
    Also, my current setup.
    Re: Help with Brake Line setup?
    Jan 2009
    Los Angeles
    So this is what I was thinking. But I'm not sure exact what size brake lines to be using. Also, is it ok to be running 3 way adapters or should I get a 5 way adapter?
    That should work but you want the valve on the front line, not the rear. You bias out front so you can initiate slides and such with the back brakes. They need to be full power all the time.
    Put the parking brake on the rears too.
    Tees will work just fine, btw
    Senior Member mech_head6's Avatar
    Mar 2009
    Milwaukee, WI
    I would not recommend putting the prop valve in the front line. You'll be giving up stopping brake performance to be able to lock the rears.
    Is there a reason you switched to a single port master cylinder? You no longer have a redundant system. What is the bore size of the original?
    Do you have the same calipers on all corners?
    • Engine - 2016 RZR 1k XP
    • Transmission - RZR 1k XP
    • Chassis - 2012 RZR 570
    • Suspension -
    Jan 2009
    Los Angeles
    Thanks for the insight guys.
    Mech, I tried rebuilding the old master along with bleeding the lines over and over again. I just can't get the wheels to lock up.
    The new Master is 3/4, do you think I will have a problem?
    On Buggynews there's a few threads about how bad these masters are and one guy swapped it out for s Ford Escort master which worked great. But it had a plastic reservoir attached.
    I got this CNC Master brand new for $50 bucks so I figured it would probably work better then the master that's on there now.
    The rear calipers are bigger, I think the are Geo Metro calipers.
    K-Fab, I get what your saying about the fronts to rears. I also remember that your a Double Footer Rally style! 👍
    And for the price of the valve, might as well get 2 for parking brake!
    Mar 2009
    Milwaukee, WI
    No doubt a non-leak in master is better than a leaking one.
    All OEM UTV have plastic reservoirs. They will be fine unless overly exposed on your car.
    Are you planning to use the prop valve as a parking brake? How does that work?
    • Suspension -
    Quote Originally Posted by mech_head6 View Post
    I'll argue this. If you put the valve in the rear you will begin locking the front wheels prematurely and also induce understeer under braking. It'll push worse the more you bias.
    The idea of the the bias valve is to start with it so that all four wheels lock up and then be able to dial out front braking. I always point the lever forward indicating full front bias (all four wheels lock up at same time). As the lever comes back it dials out front power.
    This will let you brake slide to set chassis rotation through both weight biasing forward and increasing the ability to get the rear end loose while still having maximum steering traction because the fronts are now doing more steering through gaining what would be braking traction.
    Its sort of like turn brakes for a spool rear drive train.
    Ever ride a dirt bike? You steer them through the use of the back brake as much as you do with the bars. It's similar in the car but you use a lever to control it.
    Senior Member Lance-W's Avatar
    Nov 2008
    Simi Valley, CA U.S.A.
    The proportioning valve he picked is only $25. Buy two and put them on both and figure it out from there. I've always run them on the rear line............maybe that's just a paradigm from street cars though.
  1. Brake Line Lock
    By JD66 in forum Controls and electrical
    Last Post: 05-04-2014, 01:05 AM
  2. Fuel Tank Return Line + What Axle setup ??
    By RickieLee in forum Honda's Pilot & Odyssey
    Last Post: 01-06-2012, 09:38 PM
  3. In Line Fuel Pump Setup
    By mrfreyguy in forum Controls and electrical
    Last Post: 08-15-2011, 09:02 PM
  4. Brake Line Fittings????
    By ExpertXViper in forum Controls and electrical
    Last Post: 10-26-2008, 10:35 AM
  5. brake line
    By nutnbolt2002 in forum Controls and electrical
    Last Post: 10-09-2007, 08:42 PM
