Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
    Re: Floor or hanging pedals
    I was contemplating this today as we drove through rocky crap on the road to Crown King. The RZR has hanging pedals. Brake isn't a big deal, as it has resistance and even in rough stuff you can modulate it easily enough (you use more of your leg than just a foot/ankle to control).
    Throttle pedal, on the other hand needs to mount to the floor. The hanging setup doesn't allow for a way to anchor your foot and in the rough stuff I'm on and off the throttle like I'm having seizures.
    Jun 2014
    Upper Peninsula, MI
    My dad had the same problem with his IMCA Modified, it had a hanging gas pedal, so his solution was to put some grip tape (sandpaper-like) on the floor where his heel would rest, and against the side of the firewall where he could steady the toe of his foot. Obviously this only works if you have a firewall directly to the right of your gad pedal, and it would be a better option just to go with a floor mounted pedal in the first place if you have the option
    Mar 2012
    Wellington, New Zealand
    Thanks Guys. Good point about the vibration on rough terrain and about the foot "rest" on the outside of the pedal. I am sticking with the cable actuated clutch which makes the pedals cheaper.
    Cheers.
    Mar 2012
    Check out the accelerator pedal/heel mount on this buggy.
    https://www.youtube.com/watch?v=ep3UrQR8kzk
    hanging brake, floor foot. brake type was solely because of "packaging" issues. welded half a door hinge plate to my front frame gusset, piece of wide alum. C-channel with a bolt thru it and diamond plate screwed to the front of it for a pedal.
    Mar 2012
    Quote Originally Posted by Xbird View Post
    Thanks Xbird
  1. How to get into your 3rd floor garage....
    Last Post: 08-02-2013, 11:19 AM
  2. Floor pan
    By turbotike in forum MiniBuggy.net Lounge!
    Last Post: 03-30-2012, 06:34 PM
  3. Reverse hanging brake and clutch pedals WANTED
    By stetler in forum Controls and electrical
    Last Post: 09-09-2008, 07:14 PM
  4. How to level a bender on an uneven floor?
    By SANDiego in forum Shop Talk
    Last Post: 03-22-2007, 10:22 PM
  5. Floor Opinions
    By KWiKSand in forum Frame
    Last Post: 03-21-2007, 11:45 PM
