Results 1 to 5 of 5
    Throttle cable issues
    Apr 2015
    west brabant, netherlands
    Well guus im trying to hook up the throttle om my microcar powered with a 600 gsxf in the back. brommobiel.jpg. So i got some cable from lawnmower supply and made it all fit. But i couldnt pull the cable anymore while all the bends are very big radius and i filled the whole outside cable with wd40. Any of you guys with any tips and tricks?
    Verstuurd vanaf mijn SM-G361F met Tapatalk
    Re: Throttle cable issues
    May 2013
    Easton, PA
    is it the solid wire type inner cable? if so, i'd ditch it and go with a heavy duty stranded cable like that on an atv clutch etc. Never had nothing put problems trying to make that type work.
    Apr 2015
    I dont have a solid cable but is is pretty thick (2mm) my buddy will go get some cable used for mopeds from te bicycle shop and see how that goes otherwise i'll make a solid link system. it sucks it is way harder to get parts here in holland. Thanks anyway for the tip xbird.
    You should update your profile to list your location. It's always interesting to see where everybody is from.
    A moped throttle cable might work better.
    Apr 2015
    Im trying to update my profile but i cant find how niether on te app as the mobile website
  1. Throttle Cable
    By Jerm in forum Cables: Shifter, Throttle, Clutch
    Last Post: 01-16-2015, 01:50 AM
  2. throttle cable
    By lynnbg in forum Honda's Pilot & Odyssey
    Last Post: 05-08-2009, 08:11 PM
  3. throttle cable help
    By adubaz7 in forum Controls and electrical
    Last Post: 07-07-2008, 12:44 AM
  4. Throttle Cable
    By TxBandit in forum Controls and electrical
    Last Post: 01-25-2007, 11:09 PM
  5. ST2 and throttle cable
    By buggito in forum MiniBuggy.net Lounge!
    Last Post: 07-04-2006, 04:39 PM
