Results 1 to 10 of 10
    Adding an alternator
    Telescope Master
    Aug 2009
    Tucson, Az
    Does anyone who's added an alternator to a bike engine powered car know of any compatibility issues with the stock charging system? In other words, can I just ad the feed/output from the added unit to the existing battery? Or will I have to add another battery separate from the bike system?
    If the best things in life are free why are there lotteries?
    Re: Adding an alternator
    Senior Member JD66's Avatar
    Jan 2013
    San Diego, CA
    When I added an automotive alternator to my hayabusa, I didn't have any issues. I ran it both with and without the stock stator, everything charged fine.
    If you can, drive the alternator off the crankshaft. It's better than running off the gearbox RPM input shaft since the alternator will charge even when stopped.
    Same here. I just piggybacked it into the electrical system.
    Dec 2015
    Near Pittsburgh, PA
    I would use the 1 wire GM alternator direct to battery.
    Telescope Master
    Aug 2009
    Tucson, Az
    Quote Originally Posted by JD66 View Post
    Hey JD, Do you drive the alternator under/overdrive or 1 to 1? Any concern about max RPM for the mini units?
    From what I understand you can spin them upwards of 14K - should be no issues.
    Depends on environment, I don't get much life out of automotive alternators unless I keep them down under 12krpm bearings die or diode packs melt eventually - but my engine bay is compact and hot, and there's plenty of dirt, water, etc, around, and it spends 90% of it's life at high rpms.
    The denso units can turn 20k before they fly apart.
    I bought a powermaster 8172, they are a true one wire now, and produce 30 amps at 2400 rpm at the alternator, with a peak of 55.
    Im running mine from the rpm output shaft, and i should get a benefit from the alt above 12mph.
    Yeah, but the 'fly apart' speed is far above the 'worn out and not working after 10 minutes' speed
    Powermaster rates them at 20k, not sure how long they will last at that speed though. Im sure it will take quite a bit more to blow it up.
    Most cars run them close to 3:1, and driving 200k at 2500 rpm on the engine, seems like they can take some serious revolutions.
  1. Alternator Help!
    By R_segs in forum Motor - Engine
    Last Post: 04-11-2016, 07:17 PM
  2. Alternator
    By SCEADU in forum Controls and electrical
    Last Post: 06-25-2011, 07:33 PM
  3. alternator
    By 455bird in forum Controls and electrical
    Last Post: 11-24-2009, 09:20 PM
  4. Alternator
    By Chase044 in forum Motor - Engine
    Last Post: 02-27-2008, 03:35 PM
  5. Alternator???
    By dune in forum Controls and electrical
    Last Post: 03-27-2007, 08:46 AM
