Thread: starting issue
Results 1 to 7 of 7
    starting issue
    I just recently got my carter gtr 250 running. Me and my son went out to the farm to go riding. We rode for about a hour. we decided to take a little break. When we went to go back riding, the buggy would not turn over. My lights and horn would work but buggy would only make a clicking noise. We got it back home and I put it on my charger but it said it was charged. I tried to jump the solenoid. The bolts on the solenoid turned bright red from touching them and the starter did nothing. Anyone have any suggestions as to what to look at next?
    Re: starting issue
    Is the motor siezed? You might try to pull off a timing cover or side plate, and turn it over. A 250 should turn over with a couple foot pounds, up until the compression stroke.
    If it turns over, your starter motor may be shorted internally, or siezed.
    Re: starting issue
    The motor turns over. I took the starter off and connected it straight to the battery, got a few sparks but starter motor didnt turn over.
    Re: starting issue
    Will the starter turn over by hand?
    Re: starting issue
    No. I took it to advance auto parts, and they said it was bad. That it was seized up. Does anyone know where to find a starter for it?
    Re: starting issue
    Sep 2013
    I had a similar problem. Ran fine. Then had issues starting when it was hot. then it just stopped. I stripped the starter and the brush springs had rusted shut. WD40 and a little working them back and forward and it went back to working perfectly. Not sure if you're able to strip your starter but if you can its worth checking for a fast easy fix.
    Re: starting issue
    Thanks, I may have to do that. I checked on a new starter and it was $165.00.
  1. 08 R1 not starting!
    By Byronnn in forum Motor - Engine
    Last Post: 11-22-2015, 04:22 PM
  2. R1 Starting HELP
    By Airwolf in forum Motor - Engine
    Last Post: 05-19-2010, 11:12 PM
  3. 01 gsxr 600 starting/wiring issue
    By 66triumph in forum Motor - Engine
    Last Post: 01-18-2010, 10:37 AM
  4. help with starting
    By 1983odyssey in forum Honda's Pilot & Odyssey
    Last Post: 11-20-2009, 09:20 PM
  5. help starting
    By 1983odyssey in forum Motor - Engine
    Last Post: 11-09-2009, 11:17 PM
