Results 1 to 7 of 7
    GSXR Speedo Sensor mounting
    Hi all,
    I have a 06 gsxr 1000 motor and the stock speed sensor comes mounted on motor front sprocket cover. My current buggy design doesnt allow for this cover to fit, so I was wondering if anyone has tried to relocate the speed sensor?
    Looks like the sensor is looking at divits in the front sprocket, wondering if I could mount it to say the rear axle and use a speedo healer to adjust the reading.
    Has anyone done this?
    thanks
    Re: GSXR Speedo Sensor mounting
    It should have this bolted to the end of the output shaft after the sprocket
    Ahh, got it. So due to the gear box i am using, I cant reuse that piece, however I maybe able to machine a custom piece with that same slot for the sensor to see.
    thanks
    You'll probably get a higher resolution reading with the pickup reading off of something turning a higher rpm, like the output sprocket, but I think you'll be fine picking up off of something on the axle and then using a speedo healer.
    I'm not familiar with the speedo healer other than hearing about them on this site, but is there a chance they can only "heal" over a certain range? That may dictate what component you read off of - but I don't have a clue if that's even an issue.
    I love Google!
    Speedo Healer
    That's a cool little gadget! I will be getting one for the sled speedo in my Mini-Raptor project.
    Ya I think the one I saw was like +/- 100% adjustment range
    I noticed my speedo was reading about double, I cut t apposing tabs off and it appears to be pretty close now
  1. Speedo correction
    By GateKeeper in forum Controls and electrical
    Last Post: 12-06-2013, 06:17 PM
  2. speedo
    By custom39 in forum Controls and electrical
    Last Post: 12-01-2012, 11:11 AM
  3. single seat GSXR 600
    By clayh88 in forum For Sale
    Last Post: 07-12-2010, 12:46 PM
  4. GSXR Triple-E
    By ReckONE in forum Projects in Progress
    Last Post: 03-10-2010, 02:24 PM
  5. Protodie GSXR 1000 new air box
    By ProtoDie in forum Motor - Engine
    Last Post: 12-12-2009, 09:06 AM
