Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
    Re: Hayabusa Clutch Switch Secrets
    I'm not 100% on the TLR's.
    Later in that thread one member mentioned that hooking the relay up on his bike caused the TRE to not work like it normally does, which would be a good sign that it was running the neutral map, and not the 5th gear map.
    My Hayabusa ran fine in the neutral map, and I probably could have ran it like that without harm. After trying out both, the neutral map felt a little flatter from 3k-8k, where the standard map seemed to pull harder as the revs climbed. The biggest difference is how it dropped off much faster near the redline.
    Senior Member studio5o's Avatar
    Aug 2009
    Nor Cal
    Do you have a power commander on your busa motor??? My TLS has the TRE , power commander and a full yoshimura exhaust .... I have a generic fuel map programmed into my power commander ....wonder if any of these things make a difference. I have never had a dyno comparison between the way it ran with and without the relay fix.... So I am as s much in the dark about it as well ....but it does seem to run fine judging by my seat of the pants dyno....lol...good luck and hope it gets sorted soon.
    San Diego
    When I first read this a while back I thought these are are full of it... then I got an education. My education came in the form of a Nissan Pathfinder. I could not get the ECU smog readiness monitors to clear. I kept reading about very minor voltage drops on the ECU / engine grounds, anything more than a 25 mVolt drop causes the ECU issues. I played around for a few hours and finally checked mine and sure enough there was 280 mVolt drop on my ECU grounds. Cleaned them up and added an additional ground and in 2 minutes of driving it the smog readiness monitors "cleared". I will be making modifications to my clutch switch wiring tomorrow.
  1. STM Powersports drive clutch for CVT
    Last Post: 02-03-2014, 08:09 PM
  2. Hayabusa clutch recommendations
    By NinjaRaptor in forum Motor - Engine
    Last Post: 05-19-2013, 08:36 PM
  3. Tom Pro Hayabusa lock up clutch
    By rupert14 in forum For Sale
    Last Post: 12-05-2012, 09:57 AM
  4. Hayabusa Clutch won't disengage cold
    By NinjaRaptor in forum Driveline
    Last Post: 07-14-2012, 09:16 PM
  5. Hayabusa Clutch
    By edride in forum Driveline
    Last Post: 12-13-2006, 10:55 AM
