Results 1 to 1 of 1
    Auto-Meter programmable temperature gauge
    Nov 2007
    Fort Worth Texas
    I got a Auto-Meter programmable temperature gauge, it has two ground switches. You can program a low temperature point and a high temperature point at which the ground switches will close. By using a DED-HPR Dedenbear relay connected to high temperature ground wire coming from the temperature gauge, at the temperature I set on the gauge , it will close the ground switch and turn on the light on my steering wheel. When I am driving I focus on the track and I need a big light on the steering to warn me if the water temperature is too high. I used a LED rear brake light on my steering wheel. It works really well. They supply wiring instructions on how to install the relay.
    Auto Meter 3654 2-1/16 Inch Water Temp Gauge - Speedway Motors, America's Oldest Speed Shop
  1. How to Check and adjust Nitrogen (air) shocks
    By jersdunz in forum Suspension - Wheels & Tires
    Last Post: 02-16-2011, 09:03 PM
