Results 1 to 6 of 6
    throttle cable tricks
    i am having trouble figuring out my throttle cable for my vehicle. it is a carburetor motorcycle engine that uses a flexible cable for the throttle not the push pull right now. right now it does not return the cable after the gas pedal is pushed. does anyone have any tips or tricks to lubricate the cable housing or can i somehow use a push pull throttle set up? any tips would be helpful!!! thanks in advance, mike
    Re: throttle cable tricks
    Jan 2009
    Clarkston, MI
    Put a return spring on it. It there is one already, replace it with a stronger one. (That is on the carburetor end)
    The last thing you want while driving is for the throttle to stay open ... very dangerous.
    leo
    Sep 2012
    Western Washington
    As far as lube is concerned, this works great:
    Tusk Cable Luber with Champions Choice Cable Lube | ATV | Rocky Mountain ATV/MC
    And as Leok said a better spring.
    What did you end up using for cable?
    Petoskey, Michigan
    Also depending on your pedal itself a spring there at the pedal might help too if its any resistance.
    And remember the pedal may be smooth now with little resistance but after a lot of dirt or sand or mud etc the pivots may bind.
    i have a steel core housing with low friction nylon. thought that would have low enough friction for the cable to work.
    Sep 2012
    Western Washington
    That's how mine is set up and it seems to work great, but like Nutz said there is a spring on my peddle.
    I thought mine was a little hard to push like the cable was dragging, so I lubed it with the link I posted
    Earlier.
  1. How to : Making a Throttle Return
    By maybebuggy in forum Motor - Engine
    Last Post: 02-03-2012, 11:02 AM
  2. Steps to Tune a Mikuni Carb
    By RickieLee in forum MiniBuggy.net Lounge!
    Last Post: 01-15-2012, 01:15 PM
  3. Throttle Cable for ZX9r
    By pat656 in forum Controls and electrical
    Last Post: 02-09-2011, 07:18 PM
  4. Morse cable for a busa throttle
    By hermie in forum Controls and electrical
    Last Post: 05-05-2010, 06:47 AM
  5. throttle cable
    By lynnbg in forum Honda's Pilot & Odyssey
    Last Post: 05-08-2009, 07:11 PM
