Results 1 to 5 of 5
    Master cylinder bore size
    Apr 2010
    Coon Rapids, MN
    Hi guys. I still can't figure out what bore size I need for my master cylinders. I have two twin piston calipers in front that are 1" pistons from a 450R. In the back I have the popular wilwood that has two pistons that are 1-3/4" pistons. I can't find any information on how to figure this out.
    Re: Master cylinder bore size
    Senior Member RDRacing647's Avatar
    Apr 2011
    Southern Highlands NSW Australia
    G'Day Trav,
    For what it's worth...
    I asked this very same question to a brake specialist, who provided this response ' 3/4'' bore in your M/Cylinders would be better. Using 5/8'' bore you will have more pressure less volume & a lower pedal depending on roll-back in the calipers ', I went with two 3/4" bore M/Cylinders one for the front caliper & one for the rear caliper.
    cheers
    Chris
    "Straight roads are for fast cars, turns are for fast drivers." - Colin McRae
    Senior Member Odyknuck's Avatar
    Sep 2007
    Rome Ohio
    For your application I would run the 5/8" in front and the 3/4" in the rear. The rear pistons are larger and you need to move more fluid. Just a foot note that rear brakes are the ones needed for stopping power offroad. You do not want the fronts to lock up easly. A locked front tire does not steer.
    Apr 2010
    Coon Rapids, MN
    Dang I just ordered 3/4" for the front and back last night! Oh well, I hope it works good. Also I have two calipers in the front and one in the back, so I'm sure that makes a difference. Also I have four pistons in the front, and only two in the rear! This is why I was looking for help on this. Between the number of calipers, the number of pistons, and the size of the pistons, it's tough for me to know what I need.
    Also I appreciate your input but I disagree about the front brakes. After racing quads for five years I would say the front brakes are way more important. They do all the stopping power. And I don't think it ever locked up the front brakes ever.
    Thanks for your help!
    Sep 2007
    Rome Ohio
    The 3/4" master will work on the front however it may have a stiff feel to it. They have smaller piston requiring less fluid movement. I have an 11/16" master on a seperate brake handle driving a pair of Jamar 2 piston calipers on the front of my 2500# Woodsbuggy. A 5/8" would have been a better choise as it would have given the brakes a better feel. As far as having the most stopping power (front or Back) offroad lets just agree that we can disagree lol.
  1. VW Master Cylinder
    By zuverinb in forum Controls and electrical
    Last Post: 05-28-2011, 05:38 AM
  2. Brake Master Size
    By greasemnky in forum Controls and electrical
    Last Post: 03-22-2009, 09:23 AM
  3. CNC Brake Pedal/Twin Master cylinder Assembly
    By mhall in forum Controls and electrical
    Last Post: 04-27-2008, 10:54 PM
  4. Brake master cylinder ?'s
    By lyinlow in forum Controls and electrical
    Last Post: 01-29-2007, 05:10 AM
  5. Clutch Master Cylinder
    By Baja Explorer in forum Controls and electrical
    Last Post: 09-07-2006, 10:46 PM
