Results 1 to 6 of 6
    HELP! Newbie here trying to figure out steering!
    Apr 2011
    Cottonwood AZ
    Hi everybody! First things first, total newbie here. I have started an ambitious project here, and am in need of some guidance from the buggy jedi that seem to float around this forum. A little background info...Over the last two years, I have seen this kart frame in my neighbors back yard, grass beginning to grow over the tires etc...I proposed purchasing it, they accepted. A great deal @ $50 if you ask me. What I'm working with: Motor is from a 1979 Honda ATC110, rear end looks like it came from a Yamaha quad(banshee?). And the rest is a frankenstein mash-up of aluminum i-beam, and steel tube frame. The front end looks to have come off a riding mower, or possibly older golf-kart(just guesses really). I know this needs a lot of work all over, but I am starting slow and just want to get the steering figured out for now. I have posted some pictures of the steering setup it has now. My biggest question is where do i start? Is this setup usable at all? Would a rack/pinion be a better setup? Any suggestions would be greatly appreciated(other than take it to the scrap heap )
    Thank you so much!
    Chris Johns
    Link to flikr photostream with pictures
    http://www.flickr.com/photos/christo...7626491165747/
    Re: HELP! Newbie here trying to figure out steering!
    The link has a sign in process most of us can not access it....
    There is a direct link when you are on flicker.... Paste that in to the insert image link just above where your typing a post....
    That way it will show pics in posting...
    Apr 2011
    Cottonwood AZ
    ok, should be working now, thanks!
    Senior Member 6x6TRex's Avatar
    Aug 2009
    Flint, MI
    That front end is off of a golf cart, Yamaha I believe. It will work fine but you will need a rack and pinion. I would look at the 8" Latest Rage rack.
    I had a gokart that some friends and I built using that same front end and an old tractor. We used the rack from the golf cart but the ratio was way too slow, hence the spinner.
    Apr 2011
    Cottonwood AZ
    Thanks for the help! I'll have to put some more pics up later! I'm sure i'll need lots more help down the road.
    Apr 2010
    Coon Rapids, MN
    Dang Cronz, this is an actual budget build.
  1. SSC Steering Rebuild
    By BigRed350x in forum Controls and electrical
    Last Post: 03-30-2011, 05:51 PM
  2. Will this steering work? (Bump steering?)
    By RD350LC in forum Controls and electrical
    Last Post: 06-14-2009, 06:26 PM
  3. utv power steering
    By Damien in forum The UTV Area
    Last Post: 12-18-2008, 12:00 PM
  4. home made build
    By 50nuts in forum Projects in Progress
    Last Post: 03-25-2008, 05:31 PM
