Results 1 to 3 of 3
    hayabusa wiring harness
    Cool
    can someone tell me what resister i need for the ignition switch on hayabusa harness i got side stand and clutch and fuel tank and if thats it or is there more im not useing stock fuel pump or gage cluster
    Re: hayabusa wiring harness
    The ignition security circuit needs a 100 ohm 1/4 watt resistior installed from the wire to ground.
    If you want to bypass the tip over switch youll need a 64-68k ohm resistor between the two wires.
    Remove the side stand switch and circuit.
    Clutch circuit can either be jumpered or install a pressure switch in the clutch circuit so the motor wont start when the clutch isnt pushed in. Also some years of the busa ren a slightly modified program when the clutch is engaged.
    Vendor yoshi's Avatar
    Sep 2005
    Broken Arrow Oklahoma
    Quote Originally Posted by busasandrail View Post
    If it's an 07 or older....
    If it's an 80 or newer it needs a 100ohm resistor installed between the wire and hot.....
    www.SinisterSandSports.com
    918-521-3736
  1. Ignition Switch Bypass
    By azmsp84 in forum Controls and electrical
    Last Post: 05-08-2015, 05:19 PM
  2. R1 stand alone wiring harness
    By ghettosled in forum Controls and electrical
    Last Post: 12-02-2008, 11:25 AM
  3. redoing M/C wiring harness
    By bajaBrothers in forum Controls and electrical
    Last Post: 10-11-2007, 08:55 PM
  4. hayabusa wiring harness...
    By yoshi in forum Controls and electrical
    Last Post: 07-23-2006, 06:18 PM
