Results 1 to 3 of 3
    Slave cylinder question
    I just ordered the slave cylinder from desert karts, shown in the image. Do I simply attach the end with the wing nut to the clutch lever on the engine and then make a tab and bolt the other end to the frame?
    I am assuming this is a pull type slave cylinder... but please correct me if I am wrong.
    Thank you!
    Andy-
    Re: Slave cylinder question
    Senior Member b-boy's Avatar
    Nov 2007
    quebec,canada
    you got it right Andy I got the same one but instead of pullin directly on the lever it pulls on the cable I could take pics if you want
    If it is not a hassle some pics would be useful. Thanks for the help and info.
    Andy-
  1. Quick question about trailing arms
    By andy777bmx in forum Suspension - Wheels & Tires
    Last Post: 01-22-2009, 07:32 PM
  2. Brake master cylinder ?'s
    By lyinlow in forum Controls and electrical
    Last Post: 01-29-2007, 05:10 AM
  3. Replies: 68
    Last Post: 11-19-2006, 07:15 PM
  4. Clutch Master Cylinder
    By Baja Explorer in forum Controls and electrical
    Last Post: 09-07-2006, 10:46 PM
  5. Hayabusa Clutch Slave Cover
    By xqwzit in forum MiniBuggy.net Lounge!
    Last Post: 02-02-2006, 08:15 PM
