To step away from the drive train on this, they erroneously call for using 3/4" tubing with a 1.050" outside diameter....tubing is measured by its outside diameter and not inside. Pipe is measured by its inside diameter. So am I supposed to use tubing or black pipe for the cage and A-arms? Pipe is malleable and heavier (generally) compared to tubing.
Thread: ST2-NG questions
Results 31 to 40 of 46
- Join Date
- Sep 2017
- Location
- Lincoln, Nebraska
- Posts
- 189
12-25-2020 03:52 AM
12-25-2020 10:17 PM
The Shredder II plans use pipe for the upper roll cage. I also recall a conversation with the owner of the local Metal Supermarket franchise and he stated that black pipe is stronger than most people think.
However, if it were me, I would just go with 1" tubing. Tubing is more common than pipe on these builds and adjusting between 1" and 1.05" outer diameter shouldn't be too hard to figure out.
- Join Date
- Sep 2017
- Location
- Lincoln, Nebraska
- Posts
- 189
12-25-2020 10:37 PM
Yeah that's what I'll do. Nothing should really change, maybe be a bit lighter as well. Contemplating on using the polyurethane bushings or just go with heim joints for the inner a-arm. Outer front calls for heim joints.
- Join Date
- Nov 2014
- Posts
- 87
12-26-2020 12:05 PM
Heim joint or delren bushings. Poly is way to soft and will allow for to much movement in the arms.
- Join Date
- Sep 2017
- Location
- Lincoln, Nebraska
- Posts
- 189
12-26-2020 08:09 PM
Interesting that they would recommend those bushings for the buggy builds, except I think for the Megalodon/2.
- Join Date
- Sep 2017
- Location
- Lincoln, Nebraska
- Posts
- 189
02-25-2021 11:34 PM
Would it be worth switching the front end design of using trailer stub axles and hubs for ATV/UTV hubs that have disc or drum brakes to have front and rear brakes, instead of just having a single rear disc brake?
- Join Date
- Sep 2017
- Location
- Lincoln, Nebraska
- Posts
- 189
02-28-2021 12:53 AM
Any suggestions on what quad or UTV to get hubs from that's two wheel drive? Would it also be better to go with an OEM style or is there a better aftermarket option?
- Join Date
- Jun 2006
- Location
- Posts
- 10,765
02-28-2021 01:16 PM
Hmmmmm....
I don’t know quads well enough to even begin to give advise on that (I run away from those wretched machines!) and a 2wd UTV, uh... What about that small single seat RZR? It it 4x4?
Maybe one of the utility UTVs?
- Join Date
- Sep 2017
- Location
- Lincoln, Nebraska
- Posts
- 189
03-02-2021 02:12 AM
Only 2wd UTVs I know of are the Odysseys, John Deere Gators, and some flavors of the Kawasaki Mules. I believe the latter uses more or less a MacPherson strut type suspension up front.
New guy with questions
By Johny5 in forum The Welcome MatReplies: 7Last Post: 01-10-2015, 06:20 AM -
Few Questions.
By Grandreaper in forum FrameReplies: 11Last Post: 07-02-2012, 12:23 AM -
New Here got a few questions?
By brimmabuggy504 in forum MiniBuggy.net Lounge!Replies: 7Last Post: 12-22-2009, 09:22 PM -
R&P questions
By voodoochikin04 in forum Controls and electricalReplies: 3Last Post: 09-14-2008, 12:49 PM -
FNG questions
By ff2903 in forum MiniBuggy.net Lounge!Replies: 4Last Post: 05-08-2008, 10:06 AM
