Page 11 of 12 FirstFirst ... 9 10 11 12 LastLast
Results 101 to 110 of 114
    Re: ST2-NG questions
    Sep 2017
    Utica, Nebraska
    If it's in 1/8 of an inch even 99% pure Al will take a few knocks. It's really down to cost vs how hard you are going to punish the underside.
    You could also go mild steel just much thinner than 1/8.
    Anyone else have any thoughts?
    I've thought about going 14ga for steel.
    .125” aluminum (5000 series, not 6061) will be sufficient but it tends to stick on rocks and will deform around tubes if hit right.
    Look at 3/8” (8mm) UHMW plastic sheet. It’s extremely tough, slippy as shit and does a killer job. It’ll deform and then return.
    I’m using nut inserts in my frame with button head cap screws screwed in flush (the UHMW will deform a tad w/o issues).
    Search UHMW and/or skid plate in the Mini-Raptor thread for pix.
    I had seen that pop up when I happened across a similar question being asked on Pirate4x4. I'm unfamiliar with that material, but I'll definitely give it a good look over.
    It's not that I'll be rough with the undercarriage, but I'd like to be prepared in case I decide to do something really stupid or Murphy tears his head and SHTF while riding. Rather be a bit over prepared than under.
    I want to say that the 3/8" UHMW is priced similar to 1/8" aluminum (don't hold me to that.) I got lucky and came across a couple of remnants that the company here in Phoenix had on the shelf so I got them pretty cheap.
    It's worth a little digging to see what the stuff does cost.
    It's odd - when you slide over stuff, you can feel the floorboard flex under your feet and then return to normal.
    It's so slippy that I think you actually accelerate when it takes the weight of the chassis off of the wheels.
    Sep 2017
    Utica, Nebraska
    Long as it holds up to abuse I'll definitely give it a try for sure. I'm guessing just cut it to size with a circular saw?
    Yes, circular saw, jig saw. Heck, the thinner stuff can be scored with a sharp knife on both sides and then “flex broken”. It’s cool stuff to work with.
    I have two pieces for my skid plate and took a router to each of the edges on the seam so the front of rear piece is the upper overlap to the front’s lower lip.
    Sep 2017
    Utica, Nebraska
    My dad and brother came down for Thanksgiving, bringing the snowmobile with them. Want to see if I can get it running first before I continue to order buggy parts. Should have some free time over the next few weeks.
    Duck in a Tux jimmyg's Avatar
    Sep 2016
    Bendigo AUS
    Let's hope you fire it up without to much hassle. Keep us posted how you go.
    Sep 2017
    Utica, Nebraska
    I do my best at doing updates if anything note worthy happens or I have stupid questions to ask.
    Sep 2016
    Bendigo AUS
    No such thing as a stupid question around here.
    Sep 2017
    Utica, Nebraska
    Well if that's the case lol, how many amps does a Prius power steering draw? I may look into getting one for this project if the manual steering gets a bit too stiff, or even get one for the VW sand rail project.
    Sep 2017
    Utica, Nebraska
    Was a bit warmer today so I worked on the sled a bit. Had to pick up a 13/16" spark plug socket. Poured some 50:1 mixed gas into the cylinders. Found plugs are not getting spark. So narrows it down to a couple items, Bad CDI, kill switch, bad ignition switch, or bad stator. I have a kill switch, but it's a huge PITA to install it. It'll probably be very difficult to find the proper CDI box. Hopefully I can get it to run, but I have put out some feelers to another sled or a motorcycle.
  1. New guy with questions
    By Johny5 in forum The Welcome Mat
    Last Post: 01-10-2015, 07:20 AM
  2. Few Questions.
    By Grandreaper in forum Frame
    Last Post: 07-02-2012, 01:23 AM
  3. New Here got a few questions?
    Last Post: 12-22-2009, 10:22 PM
  4. R&P questions
    Last Post: 09-14-2008, 01:49 PM
  5. FNG questions
    By ff2903 in forum MiniBuggy.net Lounge!
    Last Post: 05-08-2008, 11:06 AM
