Results 1 to 8 of 8
    Alberta Velociraptor
    Hey, I bought the prints yesterday and got some pricing on steel before I start buying anything/everything any advice? I priced out .065 tube, It was recommended in another thread.
    Thanks,
    (Doesn't seem to be a lot of traffic on the site, any other sites for more information?)
    Re: Alberta Velociraptor
    Senior Member Jerm's Avatar
    Dec 2013
    Ontario Canada
    I have a great deal of .065" wall tube on my buggy, but I used some .100" wall on the suspension mounts and critical members.
    With a properly designed cage you don't need the heavy wall stuff everywhere.
    Quote Originally Posted by Jerm View Post
    With a properly designed cage...
    Do you figure Badlands is a properly designed cage?
    Dec 2013
    Ontario Canada
    I do not know that design very well so I can't say for sure.
    Basic principal is load paths. Connecting tubes from suspension points are one place to start. Another thing to consider is if in a roll-over, the roof tubes should also have a good load transfer down to the base frame.
    It's not a really a buggy its more of a go-kart, no suspension
    The recommended motor size is 9-23hp, I've got an old two-stroke 200cc 21hp motor I'm going to try and use.
    Also I have priced pretty much everything out on the prints, I'll post the final price with some what of a breakdown.
    So I've priced most everything out that is on the plans, I know a guy could get the price down but the total is $2,700.00 no motor
    Steel = $673.00
    Nuts & Bolts = $67.81
    Princess Auto = $450.00
    Mis = $1,427.50 (tires/rims/steering wheel)
    I think Badlands had the price with out the motor coming in at $1,000-$3,500 so thats fairly accurate, not sure how you get it done for $1,000.00? Everything i priced was new and as per Badlands plans, So if i did some more research I could probably save $800.00? For example the tires got priced at $575.00 and I found rims/rubber for $200.00 used, so thats almost $400.00 knocked off.
    Any idea what the other buggies cost?
    Mar 2015
    Yettem California
    I wouldn't use .065 for the roll cage on that one , plans call for 1-1/4" sch 40 pipe that is about 1-5/8 OD and a little over 1/8" thick
    Dec 2010
    discovery bay CA
    glad some one else pointed it out its pipe not tube in the plans.
    i built the "pan" long time ago never got around to finishing it and was just kicking around the idea again.
  1. Alberta, Canada Registration?
    By cdnjaguar in forum MiniBuggy.net Lounge!
    Last Post: 03-28-2015, 01:12 PM
  2. velociraptor basic buggy
    By samsonjohn in forum Projects in Progress
    Last Post: 03-23-2015, 09:06 PM
  3. Driver size limit for Velociraptor
    By vegasloki in forum Badland Buggy Group
    Last Post: 08-15-2012, 08:26 PM
  4. ANY ST2'S IN THE ALBERTA AREA??????
    By TWR11 in forum ST2
    Last Post: 05-18-2008, 09:16 AM
  5. Alberta Panther
    By 748guy in forum Projects in Progress
    Last Post: 03-25-2008, 11:21 AM
