Thread: Need angle help
Results 1 to 6 of 6
    Need angle help
    Hey guys
    looking at the buggy plans for the st4 and it says that i need an overall angle of 88 but when we do 44 and 44 it is not correct. also when we only have a 45 degrees chop saw.
    what is the formula or calculation that we are doing wrong
    thanks
    Re: Need angle help
    Senior Member dangeranger93's Avatar
    Nov 2015
    Monroe mi
    with a 45 degree saw you cant get 44 degrees unless it goes past some, might need to break the grinder out and do it the old fashioned way
    Re: Need angle help
    Jan 2007
    Metamora, Michigan
    When angles are near 45 degrees it's easy to ef up. This is because you can accidently use the wrong side of the cut.
    The 2 mitered pieces to make 88 are actually 46 and 46
    44 and 44 are what is removed.
    Does this make sense?
    Re: Need angle help
    What is the formula for that is there
    Re: Need angle help
    This is the 3rd thread with this same question.
    Is it ground hog day?
    https://www.minibuggy.net/forum/proje...-help-st4.html
    Re: Need angle help
    Jan 2009
    Los Angeles
    Ground hog Day, love that movie!
    Hope you haven't already started cutting material.
    I don't mean to be rude but If your already having a hard time with angles then the rest of the project is gonna be a major headache!
    First off you need to but or make an Angle finder/Protractor.
    Either store bought or 2 pieces of flat bar screwed together on one end.
    Finding your miter cuts with square is a lot easier to start off with before cutting round.
    You can draw your desired angle on the floor with 2 intersecting lines. Lay 1 piece of tubing on 1 line and the other tube along the opposite line so that one tube lays over the other at the angle point.
    Now use a marker and mark both tubes where they intersect on the outside of the bend and the inside of the bend.
    Lift up the tubes and draw a line between both points that you marked on each tube.
    That's your degree line to cut on which will give you 2 perfect miter cuts on each tube.
    I hope this makes sense, but I have a feeling I may have just made things more complicated for you.
    Sorry about that. In my head it looks easy but describing the method isn't.
  1. GSX600 angle and oil pan
    By maybebuggy in forum Motor - Engine
    Last Post: 02-15-2012, 09:11 AM
  2. max angle for 930 cv
    By Damien in forum Driveline
    Last Post: 01-16-2012, 01:34 PM
  3. Rear Inner Pivot Angle
    By KrunchWorkz in forum Suspension - Wheels & Tires
    Last Post: 08-14-2010, 02:05 PM
  4. Lets Talk Engine Angle Need Opinions.....quick
    By VINDEL in forum Motor - Engine
    Last Post: 02-22-2009, 11:00 PM
  5. ACKERMAN ANGLE
    Last Post: 05-07-2008, 01:34 PM
