Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
    Re: HELP! laser shops can't cut these parts? no ones home at BL
    Bend-Tech Dragon Master
    Nov 2009
    In autocad- try selecting one line and run _pedit , turn into poly line then join and select the entire shape (don't worry about extra non-connected stuff).
    It'll either join it all and close it or you will see the gaps.
    I wish ACAD had a function like my gibbscam - on import you can autoconnect with in a certain range (ie 0.025" for example).
    Senior Member SamR's Avatar
    Dec 2013
    Surrey, BC
    Yep, converting to polylines should help sort out any errors. We had a table at school that for whatever reason wouldn't set the leadin/outs properly with plines, so I would convert everything to check the loop then explode them after.
    Also try running the command OVERKILL. It'll merge any overlapping lines into one, that is often a problem that comes up.
    Laguna Niguel, Commifornia
    Try the command OVERKILL. It will remove any duplicate lines. Chances are this is what is annoying the laser cutters. I would find it hard to believe that there are a bunch of endpoints that are not correct.
    edit: Whoops, looks like I should read the previous posts completely. Sam nailed it...
    UPDATE: I re drew the parts and sent them to my buddy to get laser cut and they worked no problem! Don't know why his files don't work, but I finally picked up the spindle pieces I've been desperately needing! Laser cut parts make my plasma cut parts look like junk! Anywho, I would post pictures, but for some reason even after I resize them in paint they won't upload? I'll try to get time to make an imageshack account.
    Nov 2015
    Philippines
    After reading this thread, I'm having second thoughts about buying plans from Badland. I was considering to buy the ST4 plans. Are there problems with the ST4 files for laser cutting or does this concern another model only?
    Would you suggest an alternative for a two seater buggy plan or is the ST4 still a good choice?
    Chris
    Look into some of the Rorty models.
    San Diego
    I just had my ST4 parts water jetted and they did not mention any issue with the files. Cost around $1k for all the parts plus material of apx $400. It aint cheap but all of the parts fit together like a jigsaw puzzle. I did have to run a flat file over the slots one or 2 times and the same goes for a round file on the round holes.
    Nov 2015
    Philippines
    Thanks for your replies, Glamisman and K-fab!
    Quote Originally Posted by Glamisman View Post
    That sounds quite encouraging in regards to the ST4, except for the higher than expected price. $1400 would be a big chunk of the overall budget.
    Yes, the Rorty models look really good, too. Are they more difficult to build? The R16 has a reasonably priced laser cut kit. The R82 looks like a suitable design for a two seater, somewhat similar to the ST4. I'm planning to use a small car engine for the buggy due to non-availability of suitable motorcycle engines in this country.
    The Rorty's rear suspensions look more complex and harder to adapt to a lengthened rear section. In your estimation, would it be more difficult to fit a car engine into a R16/R82 than into an ST4?
    Quote Originally Posted by chriswayg View Post
    I've only seen the ST4 and Rorty cars, never been in one or part of a build. There are quite a few of both on the site - find a more recently updated thread on each and ask these questions there.
    It seems that the R cars have more room for something like a car engine - but that's total speculation on my end.
  1. Replies: 379
    Last Post: 01-26-2017, 03:28 PM
  2. Micro Stub Fundamentals
    Last Post: 04-06-2015, 11:28 AM
  3. US machine shops for making Edge parts?
    By jemo in forum Suspension - Wheels & Tires
    Last Post: 06-02-2012, 05:55 PM
  4. Good deeds..... By Punkur67
    By yummi in forum MiniBuggy.net Lounge!
    Last Post: 10-11-2009, 10:25 AM
  5. Laser Cut parts
    By elmariachi in forum Frame
    Last Post: 05-28-2007, 05:15 PM
