Results 11 to 20 of 24
    Re: st4/megalodon build
    Oct 2009
    Quote Originally Posted by nicolasdriver View Post
    This is a reverse from an mxz 1200 snowmobile
    Senior Member Jerm's Avatar
    Dec 2013
    Ontario Canada
    No kidding, please post more pictures and details on that reverse chaincase. Looks like you're adding some flanges to each side for CV's. What is the gear ratio on that chaincase?
    Outboard support for that sprocket on rev box? Real slick find.
    Oct 2009
    That outboard shaft was my concern . But the cav bearing is a cool find looks like a good idea Are ya gona do a suport in the input shaft
    There is going to be a bearing on the sprocket shaft.
    That seems like a LOT of power for that little chaincase?
    I would guess you will have to mount it very well,if the casting flexes its all over.
    Good luck, I hope it works.
    There is going to be one aluminium plate on each side
    Rear Wheel hub.
    It started as a cavalier hub:
    By leok in forum Barracuda
  3. Kids Kart Build
    By Nobody077 in forum Frame
