Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
    Re: How do i c-notch tube at non 90 degrees
    Quote Originally Posted by ironknot View Post
    Here's a link to a calculator that gives a patten for notching.
    Tube Coping Calculator
    Quote Originally Posted by chuckorlando View Post
    Get ya one of these 1 1 4" OD Pipemaster Contour Gauge for Tube Notching | eBay
    Then you just trace the pattern onto your tube and grind it out
    Did you guys all miss the part where he said square tubing?
    Even with a tubing notched, square is tricky to load. A vice and a hole saw in a mill is the best way. Not sure if a drill press would be rigid enough. Maybe if you went real slow on the feed.
    Senior Member ironknot's Avatar
    Feb 2012
    Birdwoodton
    Well yes
    Thanks Ironknot
    ahahahahahaha. Maybe break out the old card board
  1. CNC plasma tube notching w/ bendtech.
    By JGSturbo in forum Shop Talk
    Last Post: 06-11-2016, 11:34 PM
  2. Bend tech vs solidworks
    By schwabm in forum The Drawing Room
    Last Post: 05-01-2012, 05:05 PM
  3. Tackas with pro tools die kinking?
    By lost26 in forum Shop Talk
    Last Post: 03-29-2012, 02:05 PM
  4. tube rotation
    By Stomper in forum Shop Talk
    Last Post: 11-04-2008, 07:58 AM
  5. 'cheating' cv angles/ axles front to back
    By Radiodude in forum Driveline
    Last Post: 01-04-2008, 04:48 PM
