Results 31 to 34 of 34
    Re: Engine change for the Tazcar
    #31
    I don't know how you have things plumbed but there should be a bleed line at the top of the outlet of the engine - it "should" release the air trapped in the top of the head area.
    As odd as this may sound, get the nose of the car as high as you can (side of a dune, winch and a tree) - like wheelie high and then see if that will move the air to the radiator where you can get it out.
    Bleeding should be that much different, as the heat exchanger are just funky radiators. It's a line in and a line out on either system.
    #32
    Well it looks like nobody plumbed in a bleeder valve, I ended up just burping it like you would a car motor by squeezing on the inlet and outlet hoses with the radiator cap off and watching the flow, after I did that a few times, you could see the coolant level dropped about 4 inches, so I put the radiator cap, I ran the snot out of it today and never got an overheat light or thermometer icon, running great now but thanks for replying!!
    #33
    Good! Glad to hear that it's playing nicely now.
    #34
    Hey! What rims are you running in the rear with the 28" or 29" tires. I have the 1st Gen tazcar with Apex and want to go bigger from the 26" and am running Douglas 190's 4/156 rims. Thanks
  1. Tazcar - Under New Ownership
    By JD66 in forum Projects in Progress
    Last Post: 11-07-2017, 05:04 PM
  2. Tazcar for sale
    By Laidbackduner in forum Craigslist, E-Bay and Internet listings
    Last Post: 03-27-2016, 02:50 PM
  3. Cost to change ratio/quick change
    Last Post: 11-15-2012, 10:02 AM
  4. Tazcar need advice before I buy.
    By emmagator in forum MiniBuggy.net Lounge!
    Last Post: 11-25-2009, 04:54 AM
  5. Tazcar review
    By fuller34 in forum The Welcome Mat
    Last Post: 05-16-2008, 09:35 PM
