Results 1 to 3 of 3
    6.5hp clone can't stretch it's legs
    May 2016
    Massachusetts
    I built a mean gx200 clone that should be around 16 hp. Last year I ran it with a clutch @8hp and hit 44mph. This year I doubled the power and ran a tav. The problem I have is the over drive isn't allowing the engine to peak. How can I get the cvt to stay out of overdrive till I hit a higher rpm? Also a bigger sprocket isn't an option due to tiny tires.
    Re: 6.5hp clone can't stretch it's legs
    S.W. Michigan
    had the same thing with similar engine and clutch set up.
    did a lot of clutch expirementing and tuning on that one
    in the end needed more gear reduction / bigger sprocket but that means bigger tires
    with Cv tech clutches we are using 7:1 gear reduction is needed for full travel on the clutch
    They sell different springs for those clutches, what color are you using now?
  1. Lotus 7 Clone
    By Hambam in forum Asphalt Runners
    Last Post: 03-23-2018, 07:15 PM
  2. Single seat gsxr powered buggy on the home stretch.
    By knowak24 in forum Projects in Progress
    Last Post: 09-20-2014, 12:07 AM
  3. Stretch you solid axle
    By Chikin in forum How To Do It
    Last Post: 10-28-2013, 10:02 AM
  4. Honda Clone GX390 engine!!!
    By ringgo1star in forum For Sale
    Last Post: 01-26-2011, 09:24 PM
  5. Honda clone governor removal
    Last Post: 04-21-2008, 05:04 PM
