Thread: Busa Datsun
Page 3 of 11 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 105
    Re: Busa Datsun
    #21
    Senior Member Akpilot's Avatar
    Anchorage Alaska
    [/IMG]Busa Datsun-a026.000-1-.jpg
    She is going to be real tight, on the Roadster the frame rails get real skinny only where the engine needs to be
    So I got out the Plasma and clearanced the frame a little bit.
    No room for header primaries so I'll just make a short turbo header
    Ak
    Re: Busa Datsun
    #22
    This is gonna be SWEET!!!
    I was worried progress had stopped since it's been a while, glad to see your still working on it.
    CANT WAIT to see it GO!
    Re: Busa Datsun
    #23
    Anchorage Alaska
    Thanks Lug, just got busy over the holidays, I'm slow but persistent.
    Made sure hood would close, I didn't want to do some 70's hood scoop, I want it to look stock.
    Pretty close to hood, I'll have to put some 90 degree elbows to move the throttle bodies down.
    Start of the engine mount.
    Finished forward mount. I figure I can't build the back mount until I build the header and route the down tube. The steering, engine mount and down tube will be competing for the same space
    Ak
    Re: Busa Datsun
    #24
    Anchorage Alaska
    Here is the start of the header, Knew this was not going to be easy so I used my CAD skills.
    The cardboard aided design work like a charm, using 3/8" stainless for the mounting as I'll build bracing off it to hold the weight of the turbo. Hopefully keeping the cracking to a minimum.
    Two and Three cylinders 45 degrees down to start.
    Ak
    Re: Busa Datsun
    #25
    Anchorage Alaska
    Basic header layout.
    Cutting the donuts to form the collector.
    Number one and four cylinders forming the up turn.
    Engine and header in chassie, not sure on the angle of the mounting flange yet so that is not welded, I'm thinking of tilting it towards the inner fender to give more clearance for the engine.
    Ak
    Re: Busa Datsun
    #26
    Thats awesome work!!!
    Re: Busa Datsun
    #27
    Looks like a lot of tedious and time consuming work, header turned out excelent AK
    Re: Busa Datsun
    #28
    Looking good!
    I race, therefore I am
    Re: Busa Datsun
    #29
    update?
    Re: Busa Datsun
    #30
    Anchorage Alaska
    Yea unfortunately I've been hard at it but I'm not dealing with anything good to post here. The car is 50 years old car and I'm chasing rust issues before I can move forward, also waiting on parts.
    This is what I've been dealing with, drivers side floor boards, yea that's the frame and floor.
    Made some door braces
    Made a rotisserie, my plan is to get a solid body and get the car working, then work out any issues and put body back on rotisserie and change color to silver.
    Cut out both floorboards and making patch panels all over the car
    I did take some "Fun Time" and made the gauge mount
    Right now the floorboards are ready to weld in now but need to finish the exhaust, mount reverser and currently starting on the wiring and access without floorboards is great. It shouldn't be long before I have some good pictures of progress.
    Ak
  1. R1 vs. Busa
    By Andy_1972 in forum Motor - Engine
    Last Post: 01-09-2011, 07:16 PM
  2. Morse cable for a busa throttle
    By hermie in forum Controls and electrical
    Last Post: 05-05-2010, 06:47 AM
  3. Busa motor - Pulley possibilities
    By Jacob_Wisdom in forum Motor - Engine
    Last Post: 10-11-2009, 05:08 AM
  4. Busa motor in car...just running...a few questions
    By turbomatt in forum Motor - Engine
    Last Post: 08-11-2009, 10:09 PM
  5. How much hp can YOU get out of a busa?
    By P-Dog in forum MiniBuggy.net Lounge!
    Last Post: 02-24-2008, 01:09 PM
