Thread: Busa Datsun
Page 2 of 11 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 105
    Re: Busa Datsun
    Senior Member Akpilot's Avatar
    Anchorage Alaska
    Thanks for the replies,
    The rear axle in the Roadster is a open diff and the the stock engine at 93 hp it is a one wheel wonder . The LSD is very expensive and really hard to find much less keep clutch packs in it. Other owners use RX7 rear ends, but just about anything will work having it cut down. Talked to a friend who builds Toyota trucks and he thinks the light weight truck axle that is undesirable for large tires would work good. Unlimited supply of OEM LSD and large selection of gear ratios. I'm leaning this way but thought it would be more efficient with a quaife Fnr.
    Thanks Jeep401 for real world experience- I'll put that option to rest, and go with the seemingly unanimous opinions of the rear axle with the inline reverser.
    Been a while since I posted pictures on this site, I now use a iPhone and the pics are too large. Got a photo bucket account and will work on getting some pics of the car and build.
    Ak
    Re: Busa Datsun
    Petoskey, Michigan
    Sometimes if pics are to large you can email them to yourself and it automatically cuts them down to less bytes. Then they post. It has worked for me.
    Re: Busa Datsun
    Anchorage Alaska
    Alright Nuts, lets try this.
    Looks like they are click-on pictures.
    I just weighed the car, came in at 2,065 lbs. With taking out the cast iron engine and trans, hopefully I can keep this thing at around 1700 to 1800 lbs. Should make the car scoot.
    Ak
    Re: Busa Datsun
    Dec 2007
    PERTH WESTERN AUSTRALIA
    C'mon Diablo,lift ya game Mate!
    Trying to wear out BEFORE I rust out!..........Now just trying to getouta Bed!
    I drink...........therefore I am!
    Re: Busa Datsun
    Ditch the rear axle for something stronger with more parts availability.
    If you go the Toyota light truck route (which I would suggest), I have a limited slip diff for a Tacoma that I will make you a deal on...........
    Re: Busa Datsun
    The 1977/1982 toyota carolla would have a lug pattern of 4/115
    Re: Busa Datsun
    Lug pattern is easy to change. finding gear sets and posi's for obsolete rear ends is not.
    Re: Busa Datsun
    Petoskey, Michigan
    I would look at a mazda miata rear end.
    Re: Busa Datsun
    Laguna Niguel, Commifornia
    I was going to suggest a Miata rear end as well. I would graft the whole rear clip in. Performance parts are readily available too. Grafting the front suspension in might not be a bad idea either. Better brakes all around on top of the "modern" suspension would certainly be a good idea with the busa powerplant. There are some FAST Miatas! I drove one once and was very impressed.
    Re: Busa Datsun
    Anchorage Alaska
    [/IMG]Well after the Holidays - daughters wedding ect., I'm finally starting to tear down the Datsun for the swap.
    Pulled the motor and started to pull body panels off, oh the rust What else would I expect from a almost 50 year old car. I'm going to replace the floor boards but leave all the body work until after I get her on the road - maybe next winter do the body and paint.
    Pulled the engine.
    Engine mounted transverse and will have a drive shaft going back to the X bracing to a Yoshi supplied Reverser and then to the stock rear axle for now.
    Ak
  1. R1 vs. Busa
    By Andy_1972 in forum Motor - Engine
    Last Post: 01-09-2011, 07:16 PM
  2. Morse cable for a busa throttle
    By hermie in forum Controls and electrical
    Last Post: 05-05-2010, 06:47 AM
  3. Busa motor - Pulley possibilities
    By Jacob_Wisdom in forum Motor - Engine
    Last Post: 10-11-2009, 05:08 AM
  4. Busa motor in car...just running...a few questions
    By turbomatt in forum Motor - Engine
    Last Post: 08-11-2009, 10:09 PM
  5. How much hp can YOU get out of a busa?
    By P-Dog in forum MiniBuggy.net Lounge!
    Last Post: 02-24-2008, 01:09 PM
