Results 1 to 2 of 2
    Radiator & fuel tank clearance
    Hi, can anyone clarify if the radiator could be mounted too close to the fuel tank ( heat wise )?
    I've just completed a custom change, mounting a small fuel tank (steel) in front of the radiator with about an 1/2 inch of clearance, the pressed edge and top of the tank seems to quite hot, but the underneath doesn't.
    sorry unable to upload pics.
    cheers
    Chris
    Re: Radiator & fuel tank clearance
    Adding heat to fuel could cause problems like vapor lock. A quick solution might be to use some adhesive backed insulating mylar from the auto parts store.
  1. Doubledown and hair pulling fuel pressure puzzles
    Last Post: 03-29-2012, 02:46 PM
  2. Fuel tank to pump question
    By rahlberg13 in forum Motor - Engine
    Last Post: 10-23-2009, 11:47 AM
  3. why do I have positive pressure in my fuel tank?
    By Damien in forum Motor - Engine
    Last Post: 02-08-2008, 06:30 PM
  4. Fuel Tank and Foam question?
    By plkracer in forum Motor - Engine
    Last Post: 11-30-2007, 10:32 AM
  5. General Rules and Information for our Database
