Thread: differential
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
    Re: differential
    Senior Member monkeyinfantry's Avatar
    Sep 2012
    Howell, MI
    more pics on that subie diff?
    My Protodie SS1000 Build
    My 1980 SR250 Build
    My 1999 Blaster Build
    2016 YZ450F
    2006 YZ450F
    2013 KLX110 stockmod
    Re: differential
    May 2013
    Cootehill ireland
    Here it is.
    Std rear LSD from a early wrx impreza thee are better helical diff fitted to sti version that are even more enclosed
    I just replaced the tapered bearings with std sealed roller bearings and used the Subaru bearing housings fitted into my plates
    Also using the drives and part of the outer hubs
    Drives are the same length
    Outer hubs are 5x100 but I will cut some old wheels to get centres for my atv rims
    Machined and welded a flange onto the inner of each drive to carry inboard brakes from the rear of a small motorbike NSr 125 I think using that caliper too
    Made a flange to adapt for a 47 tooth sprocket I had but ya could get a special sprocket cut
    Capped the diff using 4" exhaust pipe probably should have used stainless in heinsight
    Gonna fit a grease nipple for lube
    Gonna always loose a bit round the drives but I can live with that
    I cut the bearing seats from the old diff housing to weld too the inside of my mounting plates but their not hat tidy so I will machine new ones when I get a chance just for a little extra support on those aluminium bearing carriers
    Re: differential
    Senior Member BorntoBraaap's Avatar
    Jul 2013
    Salt Lake City Ut.
    This site is very cool. Its nice to see people that have come to some of the same conclusions. I have a project and its turning out much like that subie rear end. Im using honda accord stuff. Mfactory helical diffs/lsd. I will use the sealed bearings just like nivek's subie and then enclose the diff to hold lube much like niveks and also the custom sproket mounted to the ring gear location. Its so cool to see stuff like this when you have worked it out in your own head then see a site where people are doing that. I will be the only one who knows I didnt copy anyone and came up with this stuff on my own (even though it has been done before) *thumbsup*
    Here is the Mfactory helical honda diff. Its a nice little package but has not been tested yet so I cant comment on its abilities yet.
    The diff part is about 6"s wide. Should be cool .. great site.
    Edit: Oh yea ... there is a need to seal between the cv and the diff. Niveks shows how the original seal is mounted in the transmission wall. Well trany fluid is meant to lube the axle and bearing in my set up so I need to seal the axle point. I will make a cup that holds the seal and rotates with the unit, this should add life to the seal because it will only "slide" when the diff has a difference in rotation speed on each wheel. The original setup "slides" the seal with every rotation of the axle.
    Re: differential
    I'm gathering parts for my '75 Z1 Kawasaki quad project, and these solutions look very impressive. But because I'm not sure where I'll be, I'd like a locking diff or maybe a non-clutch type LS diff. The exposed carrier might still work, but I'll have to find donor from a small 4x4.
    I'm sure there's information around here on how to keep sand and dirt out of the bearings. These are a very elegant solutions to the diff and rear brake problem. Very nice indeed.
    Edit: looks like the mfactory metal plate diff might be worth looking at. It looks like you can preload the diff to get an adjustable slip. That would be very nice to dial in. I'm sure it's not cheep though.
    Re: differential
    Jul 2013
    Salt Lake City Ut.
    (Im told) a helical lsd is not like a normal open diff. It doesnt give out on one side. It applies the power to the grip not the slip. It will accomplish this without plates or springs and it is all direct drive through gears.
    This is what I have been told...I have looked at cut away views of them but still cant figure it out.
    I mistakenly thought the subie one was using sealed bearings , Opps. I see now that the original taper bearings are in the pictures. Im just going to get some large sealed ones and make some 6061 carriers for them. This will keep gunk out of them.
    I was looking at Subaru stuff (before I found this site) and just determined that it was to expensive compared to the honda stuff. Honda accord drive line boot to boot 56 bucks and its over 34"s long. The hondas have great little hubs to and they are cheap. The subie stuff is more performance minded and might suit a normal mini rail better because of weight but all the subie parts are more expensive. That I have found.
  1. Differential Options
    By diirk in forum Driveline
    Last Post: 07-03-2016, 05:56 AM
  2. My crazy idea for a reversing differential
    By ttginc in forum Driveline
    Last Post: 02-15-2010, 08:50 PM
  3. To diff or not.
    By masterfabr in forum Driveline
    Last Post: 12-23-2007, 08:15 AM
  4. Differential for buggy
    By anickode in forum Driveline
    Last Post: 11-14-2007, 03:50 AM
  5. Budget Differential ?
    By Gizmo in forum Driveline
    Last Post: 10-17-2006, 08:03 PM
