Results 11 to 20 of 23
    Re: Hoppa Street Buggy
    Keep us "posted". This looks like a fun project to watch from beginning to end.
    Are you planning to register it for street use?
    Did somebody say DAX?
    my home built Dax clone
    Feb 2008
    Birmingham UK
    oops wrong sort of Dax
    over here a Dax is a 500kg car with a supercharged V8 ........... like this
    but nice bike though
    Feb 2008
    Birmingham UK
    l will start a build thread once I get going, I have to buy a swb vitara/sidekick after around year 2000 as they switched to a power steering rack as apposed to the agricultural steering box used on the mk 1's also the rear axle is better located with a 5 bar link set up making it much easier to switch to a beefier axle if it needs it,
    once I have the vitara stripped I will need to tweak the fiberglass shell to fit on it nicely
    yes it will be fully road legal here in the uk, should be fairly rapid with 300 bhp and not much weight
    cheers Andy
    Blog Entries
    1
    Much as I hate PT cruisers, that looks like a pretty good match.
    Sep 2005
    Pacific Northwest
    Interesting project!
    Feb 2008
    Birmingham UK
    I am still working on the planning bit really, lot of decisions to be made, like do I widen the body so as the strut tops come up in the bonnet ( hood) area or leave it up high as it is and cut out the arches and slide them down the body 3 inches both would work, I favour widening the body 4 inches or so but everything is interlinked like it screws up the windscreen so I have to fins another that is 4 inches wider than the fiat one it is supposed to use,
    I have made some moulds of the sides to make up some new sections so I can add the 6" into the length I need to make it the same wheelbase as the sidekick chassis,
    l have also acquired a later sidekick to use that has a power rack instead of a agricultural steering box, this has the benefit of a shorter section of chassis infront of the front wheels allowing the body to cover it easier
    going to use this engine out of my daily driver
    Feb 2008
    Birmingham UK
    the pics of the clay buck should have been in this post but photobucket is playing up
    anyway what I was trying to show was how much closer to the top of the bonnet the wings are on the fiberglass shell than they are on the clay prototype
    I might need to slide mine down a bit
    Feb 2008
    Birmingham UK
    well a pt cruiser front grill seems to fit ok,
  1. Making a Buggy Street legal
    By The Kar Audio Guy in forum MiniBuggy.net Lounge!
    Last Post: 04-28-2016, 06:36 AM
  2. Street legal buggy in Canada
    By daaboots in forum MiniBuggy.net Lounge!
    Last Post: 02-09-2010, 08:13 PM
  3. buggy terms? street legal buggy need to find pic inside
  4. Street tires for the front of a buggy?????
    By griff in forum Suspension - Wheels & Tires
    Last Post: 07-18-2007, 02:48 PM
