Thread: Buggy
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
    Buggy
    I need to know if a 150cc engine of motor bike will pull the total weight of the buggy having 280kg
    Sent from my Shine using Tapatalk
    Re: Buggy
    Sep 2014
    West Palm Beach FL
    Geared properly it would, but it's not going to be very powerful at all. I would guess that sugar sand could be a real problem. IMHO Go bigger.
    Re: Buggy
    How about a 200cc ktm Duke engine?
    Re: Buggy
    Sep 2014
    West Palm Beach FL
    What type of terrain will you be riding on? Either of those 2 engines will get you around on firm ground, if geared properly.
    But at 280KG/617LBS I don't think either will be very good on soft terrain, like sand or mud.
    Re: Buggy
    Sep 2014
    West Palm Beach FL
    I think those Chinese 150cc buggies weigh about 180KG/400LBS. They will barely go through sugar sand, but they're only about 10HP, and use a CVT type transmission. I'm guessing your Duke should have a little more than double that 24hp? and the option to shift gears manually.
    Re: Buggy
    Sep 2014
    West Palm Beach FL
    A TRX 450R weighs 176KG/388LBS and has about 41hp. I would think you would want at least that or more. Or significantly lower the weight.
    Re: Buggy
    Okay, so what will be the minimum weight for an 200cc engine can carry
    Re: Buggy
    Sep 2014
    West Palm Beach FL
    Depends on the type of terrain you will be riding on, and what level of performance you want. With 24hp, I personally wouldn't bother with anything over 180KG/400LBS.
    Re: Buggy
    The terrain will be almost a normal ground with out any road
    Re: Buggy
    Or it would be a paddy field probably
