Page 9 of 10 FirstFirst ... 7 8 9 10 LastLast
Results 81 to 90 of 100
    Re: Another Aussie AR51 build.
    #81
    Dec 2012
    Perth, Western Australia
    Todays effort
    #82
    What let go? You suddenly appear to have excess camber on the right front.
    #83
    Dec 2012
    Lower arm bent.
    #84
    Dec 2012
    #85
    Dec 2012
    Ok so i thought I would put some photos up of how the new arm is made (well this is how I do it anyway)
    The plans actually have drawings needed to build a jig to make the arms. It consists of a flat plate of steel with a series of bolts to mount blocks of various sizes to. I had this stashed away in the shed from when I originally built it. Lucky I didn't leave it in the rain or it would of rusted.
    After cutting up the bent A arm I managed to salvage the inner tube that mounts to the chassis and the chunky steel bits at the other end where the shock and the heim joint bolt up.
    So I cleaned them up and put them in the jig.
    https://lh3.googleusercontent.com/9j...iqsAEmJg=w2400
    Looking at the plans I suss out the angles that the tube has to be notched at. Using an online notch calculator web page I print out pdfs with the curve of the "notch" on it. Cut this out and wrap it round the pipe, then use a marker pen to transfer it, then cut with grinder.
    http://www.metalgeek.com/static/cope.pcgi
    #86
    Dec 2012
    #87
    Dec 2012
    So thats where I am at now.
    The last photo is a top down view of the lower, front right hand arm (the one that bent)
    I am thinking of running a tube from the center of the top tube to the bottom left (as you look at the picture) and maybe a gusset or 2.
    #88
    Quote Originally Posted by mrniceguy View Post
    That’s probably a good idea......from the video it didn’t look like it was a real hard hit.
    #89
    Dec 2012
    #90
    Dec 2012
  1. Buggy # 2 looks like an another AR51 build
    By sodman in forum AR51 Buggy Group
    Last Post: 01-07-2016, 04:53 PM
  2. Almost everything you need to build an AR51
    By daaboots in forum For Sale
    Last Post: 08-15-2015, 07:59 PM
  3. AR51 Build in St. Louis
    By 2kmoss in forum AR51 Buggy Group
    Last Post: 02-05-2015, 01:28 PM
  4. AR51 build in KY
    By wjfawb0 in forum AR51 Buggy Group
    Last Post: 07-08-2014, 09:14 PM
  5. Tires for AR51 Build
    By 2kmoss in forum Suspension - Wheels & Tires
    Last Post: 11-21-2013, 07:26 PM
