Page 23 of 23 FirstFirst ... 13 21 22 23
Results 221 to 229 of 229
    Re: West Michigan AR-51
    Senior Member spud nut's Avatar
    Jul 2011
    Nampa, Idaho
    Absolutely agree about the front end coming up. My busa buggy on pavement lifts the front each time I shift though the first 4 gears
    Sep 2008
    Allendale MI
    Quote Originally Posted by mrniceguy View Post
    I might have missed it, but what is the purpose of stretching the buggy?
    Good question,
    The Busa will fit, however it is VERY tight. I want to allow for a larger radiator, wider stance with bypass shocks. The longer wheelbase will make the car ride even smoother.
    Nowhere near the desert.
    Sep 2008
    Allendale MI
    Well,I have made a fair bit of progress on the AR-51. I took the current design that worked very well and just kinda made it bigger. I drew up a full scale drawing to make sure things were going to work the way I planned. My center section emulates what Rick had initially designed, however with the usage of the non plunging axles, I will have no camber gain unless I adjust the outer heim joints to have 1 or 2 degrees of negative camber. I will be limiting the suspension to 38* at full droop witch will allow me to get just shy of 20" with a 12" shock. I even drew a full scale side view to locate the new engine as well. As of now, I will be running a 70 tooth sprocket in the rear and a 14 tooth up front.So below is my suspension. You may have to squint to see everything, but on the right side of the poster board are then inner pivots and the axle pivot. This shows the full range of travel. The arms will be 24" long. In this pic you can see the back of the car. I "modeled" in the engine sprocket to show the potential interference with the bulkhead. Seems to be working on paper. LOLThe below pic is of the front bulkhead plate. There is clearances for the chain. The rear bulkhead plate has the opening for the adjuster fork that I will be re using.I drew everything up on the water jet yesterday too.These plates will capture the inside of the control arm pivot points.
    Member kustomfab2003's Avatar
    Appleton, WI
    Nice!!
    CWI CWS CWE
    Sep 2008
    Allendale MI
    Well, I done messed up....
    So, my vertical spread on my inner center section is 10". In theory this is fine, however when the center of your axle is 3.5" above the bottom pivot, the upright will not fit into the 14" wheel.... or a 15" wheel...... I found this minor detail after the center section is all tacked together.
    Well shit. I will have the vertical spread at 8" now. I KNOW this will work as I drew up some templates and mocked things up.
    I should have looked at this a long time ago.
    I have the new drawings made up as well as motor mounts now. One step back, but now I can go 3 steps ahead of that.....after I get back from Philly.
    Here is a large piece of scrap. HAA I can re use the tubes though. This Sunday I should have the new center tacked up with the motor mounts in place. The new design will be a little better in the long run too.
    Bummer!
    But it makes me do a little happy dance knowing I’m not the only one that does these sorts of things.
    It sucks having to redo something like this. It's usually my luck that I have fully welded it because that part was 'done' so no need to check anything else.
    Sep 2008
    Allendale MI
    Well after my bottom lip stopped shaking and I wiped my tears away(insert image of a 4 yr old that lost a toy), I got some stuff done.
    I re drew my inner bulkhead section, re drew my inner capture plates, drew my rear uprights and also cut said parts. I ended up with an 8" vertical spread between my arms. My upright clears the inside of my wheels and we are back on track!
    Yesterday I got it all tacked up as well as actually attached to the chassis! Next up is to build the new mid rail section for the back. This will take me cutting more of the original chassis. Where the "B" pillar attaches to the mid rail is where that will get cut and a new section that is longer and wider will meet the new vertical tubes on the bulkhead. While the cradle was sitting there, I aligned it to the new engine and made the lower tabs for that. This is very important as these 2 mounts center and square the engine to the chassis. Once I get some more tube work in place, the engine will go back in to establish the upper rear mounts as well as the top front mounts. PROGRESS!
    If you close one eye and squint really hard, you can kinda see how much longer the new chassis section is compared to the original. You can also see the clamped on piece of new 1.5" square as that is how far that new section will be coming back.
    Sep 2005
    Pacific Northwest
    Delicate surgery. Nice!
  1. West Michigan Shotgun tear down
    By Deranged in forum Projects in Progress
    Last Post: 08-10-2012, 05:39 PM
  2. West Michigan R-16 Shotgun
    Last Post: 11-27-2011, 05:39 PM
  3. Misc Polaris quad parts for sale in Michigan
    By nutz4sand in forum For Sale
    Last Post: 07-08-2010, 01:57 PM
  4. Michigan buggy builders show 2009
    By ProtoDie in forum MiniBuggy.net Lounge!
    Last Post: 03-27-2009, 06:05 PM
  5. Michigan Buggy Builders Show ,,Lansing-March 18
    Last Post: 03-23-2009, 07:48 AM
