Thread: AR51 in Mo.
Page 8 of 8 FirstFirst ... 6 7 8
Results 71 to 76 of 76
    Re: AR51 in Mo.
    #71
    Jan 2007
    Slater Mo.
    Been a while since I updated here. Finally got the dash cut out and installed.
    Sheís pretty much ready to take out for a test drive. Just need to mount the coolant over flow tank somewhere.
    Re: AR51 in Mo.
    #72
    Good to see the progress! I recently moved to KC so we'll have to go try our buggies out sometime!
    Re: AR51 in Mo.
    #73
    Jan 2007
    Slater Mo.
    Quote Originally Posted by fatboy1214 View Post
    Sounds good! Iím about 3 hours East if you!
    Re: AR51 in Mo.
    #74
    Jan 2007
    Slater Mo.
    My son took some action shots of the buggy a few weeks back. I realized I posted them on Facebook but I never posted them on here.
    Re: AR51 in Mo.
    #75
    Jan 2007
    Slater Mo.
    Iíve got about 10 hours on it now and the only issue Iíve had is the idler sprocket. Once the chIn stretched out I think it was loose enough to cause it to bounce up and down and some how it knocked a tooth off the idler sprocket.
    The GSXR 1000 runs strong. It makes awesome power. But itís still not running at 100%. Thereís a big in it that I believe is related to the tps. Thereís a procedure to adjust the tps but I had the harness cut down and I think the removed the part that allows for that to happen. But other than that I couldnít be more happy with the results.
    Re: AR51 in Mo.
    #76
    That looks like a fun buggy!!!
    A long haul to finish it but you have it out on the trails. Good job!!
  1. Buggy # 2 looks like an another AR51 build
    By sodman in forum AR51 Buggy Group
    Last Post: 01-07-2016, 03:53 PM
  2. AR51 build in KY
    By wjfawb0 in forum AR51 Buggy Group
    Last Post: 07-08-2014, 08:14 PM
  3. Rick's AR51 assembly
    By RickS. in forum AR51 Buggy Group
    Last Post: 07-25-2013, 07:23 AM
  4. AR51 930 Rear
    Last Post: 10-25-2012, 04:47 AM
