The Welcome Mat This is the place for new members to introduce themselves to the board. Stop in, say hello and tell us a little about yourself.
Old 07-28-2008, 06:18 AM   #21 (permalink)
arrowhead's Avatar
Default Re: Just an old fart from Florence Oregon
I cut off the bell housing top and left the bottom with the threaded bosses to mount that side cleaned up the rest and welded a block on the right side to mount to other rail.
Cut the Honda cv's so I had the spline and a flange to weld the 630 flanges to.
Cut the hub out of a clutch disc and welded this to a 1.25 keyed shaft to mount my driven sprocket on.
Honda makes a great trans and no matter where I run I have the perfect gearset and reverse
Old 07-28-2008, 01:09 PM   #22 (permalink)
masterfabr's Avatar
What size paddles are you running?
Old 07-28-2008, 04:12 PM   #23 (permalink)
arrowhead's Avatar
1300s on 8 inch rims with tubes. This combo saves the added weight of beadlocks and slides well without hooking the sand
Old 07-28-2008, 04:23 PM   #24 (permalink)
My gawd, he's just down the road from me,, I would like to see that machine, I'm impressed with the 766lb weight of the vehicle and the Ultra Trick Tranny. See, The old farts know how to do it you young cod lickers,,,
Old 07-28-2008, 05:24 PM   #25 (permalink)
I really like the tranny setup. Couple questions. How does the keyed shaft and the part of the clutch hub stay fixed to the input shaft on the transmission? How did you setup the shifter linkage for the honda tranny? Pics of the current chain driven setup would be awesome. This would be pretty sweet to have this on a CVT setup as well. 5 speeds with reverse. Do you know how much radial clearance you have from the input shafts centerline? Just wondering if a CVT clutch would fit in there.
Old 07-28-2008, 05:36 PM   #26 (permalink)
bdkw1's Avatar
While I don't claim to be a CVT expert, I seem to remember different gear ratios requiring different clutching set-ups.
Old 07-28-2008, 05:41 PM   #27 (permalink)
jumpin jellybean's Avatar
Sweet I like the looks of the diff
youth and overexuberance will never overcome old age and trickery
Old 07-28-2008, 07:35 PM   #28 (permalink)
Jay1823's Avatar
Yes more pics would be nice. What gear do you usually leave the Honda tranny in when at the dunes. What a pain trying to figure out the total gear reduction when you factor in everything.
You sure that's an 88 tranny, what car is it out of. Those 3 piece cases came in the 84-87 cars, the 88+ have 2 piece cases. I've had tons of 88-91 Civic, one of my favorite cars. I have a 90 Si that i autocross and a 91 that's got a fully built turbo engine and yes the trannies are well made. They can take quite a beating and there so cheap to replace.
Jay1823 is offline   Reply With Quote
Old 07-28-2008, 07:37 PM   #29 (permalink)
arrowhead's Avatar
I'll post some more pics this evening for those interested
Thanks for the kind words!
Old 07-28-2008, 07:53 PM   #30 (permalink)
arrowhead's Avatar
You can use any Honda but the 83+ have a bigger input shaft. I run in 3rd normally and 4th if the boys are turning up the wick
Oregon dunes busasandrail MiniBuggy.net Lounge! 1 04-10-2008 02:02 AM
Oregon and Idaho Dunes, 2008 - Post your planned dates Gene MiniBuggy.net Lounge! 12 03-14-2008 07:37 PM
Oregon dunes trip...MARCH 15-16th??? busasandrail Events and Group Gatherings 26 03-12-2008 06:03 PM
Oregon Dunes - July 21-27 - Coos Bay DuneMe MiniBuggy.net Lounge! 5 02-25-2007 06:19 AM
Oregon dunes trip busasandrail MiniBuggy.net Lounge! 5 05-15-2006 03:09 PM
