#122 (permalink) | |
The center main frame, This includes the front suspension mounting points (OEM ) The Vin number (OEM # I cut out ) The front spindles (aftermarket) The front brakes (OEM ) The front hubs (OEM ) Front rims and tires (After market ) Hood and Fenders (after market) O'ya and a few of the OEM bolts that I reused. ha ha It must still be a rhino ![]() ![]() I can't wait to take it back to a Yamaha dealer for some service work. ![]() Last edited by stetler; 01-04-2009 at 03:17 PM. |
#123 (permalink) |
Got the main fuel rail system mounted. Just have to get a few more braided lines made on Monday.
![]() ![]() ![]() ![]() The fuel pressure gauge will be visable from the passenger side of the center counsel ![]() Here's the back panel where the relays and UCU will mount. ![]() The gear shifter in the works. ![]() ![]() And here's a closer view of the gas filler flush mounted to the side panel ![]() ![]() |
#124 (permalink) |
Every time I come to this site I look up your thread to see what you have done on this project. Thanks for posting all the pictures. I would love to see that thing run when it is finished please post some video of it.
Mike |
#125 (permalink) | |
removed the oil cooler last night and dropped it off with Todd for some modification ![]() OK, Got the oil cooler back tonight and mounted it. ![]() ![]() Mounted the Battery tray, still have to add a few support brackets off it. ![]() worked on the shifter a little more. ![]() ![]() |
#126 (permalink) |
during the week Todd got all the cables hooked up, adjusted , and working. F & R for the Jeffco and Gear shifter. Stll some more work on the actuall shifter to be done but it shifts perfect now.
Waiting on the phone call from King Shocks that my new rear bypass' are done being built. Hopefully this week and then Todd can continue building the rear arms. Old design ![]() New design ![]() the forward revese shifter ![]() ![]() ![]() the routing of the oil cooler line to the radiator ![]() another look at the fuel rail setup fully mounted and all the braided lines installed. ![]() |
#130 (permalink) |
I bought the Blue F/R shifter and yes it has a true Positive lockout. Works great, Nice and small. Here's some info in it.
MPD Racing Positive Lock Shifter Kit Anodized and spring loaded lever securely locks car into gear. Lever is bolted to mounting plates that are welded to chassis. link MPD Positive Lock Shifter & Cable |
| Sandrail build tips, tricks, and stuff learned the hard way. | yoshi | Shop Talk | 41 | 07-11-2009 04:48 PM |
| Motor Kits From The Newest Member!!! | busapwr | For Sale | 19 | 03-22-2008 06:28 AM |
| Adding hydraulics to bender. Looking 4 electric motor input | nutz4sand | Shop Talk | 12 | 12-02-2007 03:26 AM |
| Manufacturting off road vehicles.... | Bugpac | MiniBuggy.net Lounge! | 14 | 08-25-2007 02:39 PM |
