The Welcome Mat This is the place for new members to introduce themselves to the board. Stop in, say hello and tell us a little about yourself.
Old 10-07-2009, 02:57 AM   #1 (permalink)
SLICK WILLY's Avatar
Default fl250 odyssey carb question
i just bought a odyssey to restore and it has a carb on it that dont look like any carb pics i have seen on stock odyssey the jug has some porting work done on it but i think the bore is stock it needs rebuilt so the jug will more than likely need boring any one have any idea what carb it might be? its a mikuni but it dont have any numbers on it i might be able to post some pics of it thanks in advance for any help
SLICK WILLY is offline   Reply With Quote
Old 10-07-2009, 03:51 AM   #2 (permalink)
Default Re: fl250 odyssey carb question
Could be a flat slide, better than stock.
millbilly is offline   Reply With Quote
Old 10-07-2009, 11:49 PM   #3 (permalink)
thanks millbilly you are correct i finally found it on mikuni website thanks alot for your help! i have another question? i have never owned a odyssey before do they use crankcase oil or are they like a weed eater get oil from the gas? i couldnt find a drain plug or a fill spot to put the oil thanks again
Old 10-08-2009, 04:23 PM   #4 (permalink)
It's a 2 stroke, add the 2 stroke oil to the gass.
Old 10-09-2009, 04:09 PM   #5 (permalink)
i was wondering my blaster used oil in the block and in the gas
Old 10-09-2009, 05:57 PM   #6 (permalink)
LiveWire's Avatar
The Blaster takes oil for the transmission/clutch. The case case/main bearings are lubricated by the oil in the fuel. The trans oil is equivalent to what you put in the chain case on the 250 that is not integrated with the engine.
Old 10-10-2009, 03:47 PM   #7 (permalink)
your right that makes sense thanks for all your help
Odyssey FL250 with Polaris 440 / rear suspension bainer1290 The Pilot & Odyssey Forum 53 02-22-2010 11:21 PM
FL250 parts for sale PilotHawK For Sale 16 02-20-2010 03:32 AM
32mm Mikuni Carb on FL250 humjaw The Pilot & Odyssey Forum 1 08-29-2009 08:44 PM
Mikuni Carb on FL250 mslanh01 The Pilot & Odyssey Forum 2 07-26-2009 05:55 PM
Honda Odyssey FL250 83FL250 The Pilot & Odyssey Forum 0 04-15-2008 11:16 PM
